Smoke Detectors - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 09:55 PM   #1
Rewards Points: 152
smoke detectors
i want to install a smoke detector. I see my other smoke detector has a 14-3 wire inside. What's the reason for installing the red wire in the smoke detector??
humberguy is offline   Reply With Quote
Old 01-05-2010, 10:05 PM   #2
Inspector/Instructor
codeone's Avatar
The red wire in the smoke detectors inter connect one with the others. It is a signal wire so that when one goes off they all go off. This design is to try and make sure someone in a bedroom wakes up when one goes off.
Its been noted with small children this will not necessarly wake them up.
codeone is offline   Reply With Quote
Old 01-06-2010, 07:24 AM   #3
Rewards Points: 152
thanks alot, solved my problem
Smoke Detectors for Bedroom cibula11 Electrical 4 09-14-2009 12:21 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
Smoke Detectors / CO Detector Bocolo Electrical 9 02-17-2009 05:12 AM
CO and Smoke Detectors Chemist1961 HVAC 20 01-22-2009 06:43 PM
Wired Smoke Detectors? bjstewa Electrical 2 05-09-2007 08:20 AM
