Small Motor-help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 08:42 PM   #1
small motor-help
Hi to all, have bodine sm. 1/3 hp motor, 1550 rpm cont. Want to use to circulate heated water for film processing model # kci-24.
Have no paperwork, dont know which wire is which, have (4) red, blue, black, green w/yellow stripe
Any help appreciated, Thanks !!!
mxtr
mxtr is offline   Reply With Quote
Old 04-12-2010, 08:44 PM   #2
Master Electrician
need all the info off the nameplate on the motor...voltage amprage and so forth.
andrew79 is offline   Reply With Quote
Old 04-12-2010, 08:50 PM   #3
sm. motor, Andrew
Andrew, here you go 115 vlts, 110 mA, single phase, 60-hz
anything else you need ??
mxtr
Old 04-12-2010, 10:29 PM   #4
Master Electrician
either the HP of the motor or the amperage is wrong...a 1/3 hp motor should draw a few amps.
Old 04-12-2010, 10:37 PM   #5
Master Electrician
if you can get me the serial number of it, it will help immensly
Old 04-13-2010, 12:31 AM   #6
Andrew, here is s/n 0712kzkj0005. my the hp is 1/300
thanks again, mxtr
Old 04-13-2010, 12:53 AM   #7
Master Electrician
as far as i can tell there should be a capacitor with this motor as well. Did you purchase this new or used. If your interested here's the site with the motors wiring diagrams and the parts that should have been included with the motor. You can actually purchase the capacitor from them as well for fairly cheap.
http://www.bodine-electric.com/Suppo...nformation.asp
Old 04-13-2010, 10:16 AM   #8
Good Morning, Thanks, Andrew I will give this a shot.
Thank you for your help !!!!! Mxtr
Old 04-13-2010, 11:06 AM   #9
Rewards Points: 308
This is an OEM motor. You need to call Bodine and find out who owns the unit. Is this just a motor or is it a gear motor? Bodine builds gear motors. They may be able to assist with a wiring diagram, but doubtful.
This is what the colors represent on the motor connections.
Blk-5 / Rd-8 / Blu-1 / grn-yellow- Grd. These are the NEMA designations for color coding.
Old 04-13-2010, 11:10 AM   #10
Master Electrician
Bodine's website allows you to punch in the serial number of a motor and it takes you directly to the wiring diagram for that motor....check out the link above i posted...i don't have alot of capacative start motor experience and would like a second opinion. It looks to me like the capacitor is supposed to be on the exterior of the motor? Or is it hardwired internally?
Old 04-13-2010, 01:19 PM   #11
Rewards Points: 308
Good job Andrew. The wiring diagram is there and simple.
Blue - Line
Red - Line and cap
Black - Remaining terminal on cap.
OP. Click on the link Andrew provided, and paste the serial number into the required field. The diagram is right there.
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 09:42 AM
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 01:52 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 11:06 AM
small electric heater recommendation bdog1234 Electrical 9 02-24-2008 02:12 PM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 10:38 AM
