Sliding Dimmer Switch Is Warm To The Touch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 10:19 PM   #1
Rewards Points: 151
Sliding Dimmer Switch is warm to the touch
Is a dimmer switch (sliding type) generating a detectable amount of warmth (through the faceplate) cause for alarm?
The switch is all the way up.
Note: This switch does not have a "click" locked feeling all the way up. Does this mean that it likely has no separate fully closed connection at the top that bypasses the variable circuitry?
(variable resistor, or whatever).
Thanks!!!!
tgm1024 is offline   Reply With Quote
Old 05-30-2010, 10:47 PM   #2
Warmth is normal. Count up the wattage on the bulbs being controlled by the dimmer. When you take the faceplate off you'll see the watt rating for the dimmer (usually 600 watts), if you're close to that, consider putting in smaller wattage bulbs or disabling a few lights. If neither of these ideas are practical, consider a larger dimmer.
fpeftw is offline   Reply With Quote
The Following User Says Thank You to fpeftw For This Useful Post:
tgm1024 (05-31-2010)
Old 05-31-2010, 03:18 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Some case what I will do is install the metal switch plate as well that will act like heat sink to help the dimmer to work more cooler and many case it do help a bit.
The very large dimmer { 1500 w and 2000 W dimmers } have standard heat sink included with the dimmer and majorty of the time you will have to mount this size dimmer on it own junction box due the heat sink size.
Also if you have couple other switches even other dimmers or fan speed control in there you will have to derate the dimmer as well.
There is listing if you take the cooling fin off it will tell you how many watts it will reduce or the numbers of switches in the box that will afffect as well.
Merci,Marc
re: pendant lights on dimmer switch jho Electrical 11 03-26-2010 10:14 PM
Replacing dimmer switch Mike2181 Electrical 4 10-26-2009 01:12 AM
Light doesn't turn on immediately on dimmer switch Michblaze02 Electrical 3 03-19-2009 05:14 AM
Dimmer switch quit working Umabean Electrical 4 07-09-2008 01:25 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
