Sizing Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 10:48 AM   #1
sizing Panel
We are planning to upgrade our exisiting panel in our vintage 1970's mountain home. With the exception of the furnace, the house and adjoining studio is 100% electric. Our ongoing remodel includes electric tile heaters, and other energy consumers. We'd like to calculate the overall load to determine if we need a 320 or 400amp panel. Can someone advise us on a reference to do this calculation?
Thanks! Steve
Steve Burke is offline   Reply With Quote
Old 11-21-2010, 12:06 PM   #2
Master Electrician
Rewards Points: 5,082
http://www.zenfixit.com/load_calculations.shtml
try this link or google 'electrical load calculations'
brric is offline   Reply With Quote
Old 11-21-2010, 12:17 PM   #3
I=E/R
a7ecorsair's Avatar
Question: Is the furnace your primary heat source? Will all the electrical be on one meter? Will the water heater be electric?
The reason for asking is some things are considered a continuous load and have to be figured differently. For instance, if you had a 20 amp circuit feeding some type of heating device, you calculate the load at 80% which means this circuit can only have a 16 amp load.
a7ecorsair is offline   Reply With Quote
Old 11-21-2010, 12:25 PM   #4
Thanks to you both. Appreciate the link as well as the insight about sizing load on continuous loads. We will have a single meter, electric H2O heater, some electric floors, and some electric toilets (Washlet). Our fuel oil furnace is a bit of a beast and looking for other ways to deliver heat to only those areas in need. Since there is no natural gas where we are at, and propance has fewer BTUs than fuel oil we will likely keep the beast for now.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
