Single Pole Timer Switch With 4 Lines Incoming - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 12:48 PM   #1
single pole timer switch with 4 lines incoming
I'm trying to install a Leviton preset timer switch in my bathroom. I successfully installed one in my other bathroom, but it only had two wires attached (Load & Line). The second bathroom has two switches in the junction box, and four wires that connect. I've tried all types of combination, none successful. At the moment, all the white wires are connected, and all most of the black are connected. It currently works with simple one pole switches.
Should I simply run the black and whites separately to each switch? I'm not sure why they are connected since they go to different switches. I'm wondering what combo to try next.
thanks for any help.
billyjeenyus is offline   Reply With Quote
Old 09-18-2011, 01:20 PM   #2
Licensed electrician
Rewards Points: 3,832
Unless they are used as part of a switch loop white wires should not be connected to a switch. If you had a switch loop you would have a hot white and a black switch controlled hot.
Were the whites connected to the old switch?
Tags
wiring problem , wiring with extra wires
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Re-wire dual pole switch to single pole bujaman Electrical 3 05-31-2011 06:09 AM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 06:03 PM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 07:06 PM
