Single Gang Double-switch To Double Gang W/ Two Single Switches - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-15-2014, 05:25 AM   #31
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,778
Hate to say it, but your work is not better than any electrician in your area.
The plastic box needs to go. Your outlets further down are not grounded now as has been mentioned.
Spend a bit of time and get it done correctly.
Electrical connections are in closed boxes so houses don't burn down from malfunctioning devices.
Odds.........slim.......I do know however that I won't be turned into a crisp from your deficient workmanship. Remind me to never sleep in your home.
123pugsy is offline   Reply With Quote
Old 07-16-2014, 12:10 PM   #32
Licensed electrician
Rewards Points: 4,574
The different plasrtic box will have the same issue.
Old 07-16-2014, 07:15 PM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Wow... nice hack job.
Old 08-03-2014, 09:58 PM   #34
Rewards Points: 235
OK, several weeks ago, based on some comments above, I said I would change out the plastic box for a metal one. When I started the box swap I did not think that the original metal box was grounded (it was) nor was I aware that electrical switch boxes can, apparently, "spark" and do other odd things. So, here ya go....
1st pix is of the plastic box removed and the bare stud next to it.
2nd pix shows a 1/2" thick piece of wood added to the stud to center the new metal box (didn't want the switch cover to be to close to the door jamb).
3rd pix shows the new metal box installed but not wired yet.
4th pix shows it all in place.
What I learned: wiring in metal conduit is automatically grounded, having your wiring grounded is a bigger deal than I originally thought, and metal boxes CAN be added to existing metal boxes for "remodel" work. I learned that and the fact that there are some snarky electricians out there. (If you're not one of them [and not all who posted here were] don't be offended.) :-)
Thanks again for helping me get smarter.
Cheers!
Single Gang Double-switch to Double Gang w/ Two Single Switches-single-gang-double-gang-metal-box-1.jpg   Single Gang Double-switch to Double Gang w/ Two Single Switches-single-gang-double-gang-metal-box-2.jpg   Single Gang Double-switch to Double Gang w/ Two Single Switches-single-gang-double-gang-metal-box-3.jpg   Single Gang Double-switch to Double Gang w/ Two Single Switches-single-gang-double-gang-metal-box-8.jpg
'Twister'
"A professional is only a DIY-er with more experience."
Twister is offline   Reply With Quote
The Following 2 Users Say Thank You to Twister For This Useful Post:
jbfan (08-04-2014), rjniles (08-04-2014)
Old 08-04-2014, 05:49 AM   #35
123pugsy's Avatar
Good job.
Hopefully others will read this and catch the lesson.
The Following User Says Thank You to 123pugsy For This Useful Post:
jbfan (08-04-2014)
Old 08-04-2014, 11:30 AM   #36
Electrical Contractor
jbfan's Avatar
Rewards Points: 92
If you think we are snarky to you, wait until one of the pros shows his work on the pro site.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Tags
double gang , single gang
3-way Switch Used to Bybass Dimmer Perry401 Electrical 3 05-14-2014 02:20 PM
Exhaust fan/light from single switch to dual: HELP ryowens Electrical 5 01-20-2013 10:21 PM
Help Requested for Changing Double Switch to Two Singles eddj Electrical 27 12-01-2012 01:04 AM
2 ceiling fans on single wall switch Zig Electrical 5 03-06-2012 09:16 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
