This Shouldn't Be Hard - Pole Light - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By TarheelTerp
  • 1 Post By Fish_Stick
Old 05-11-2018, 12:40 AM   #1
Rewards Points: 238
The concept is very simple - mount a dusk to dawn pole light with an extension arm. Okay, couple of lags and you're done...however I can find almost nothing on how to wire these things up with the arm. I see if you mount them flush on a pole there's a 1/2 ko for conduit but how do you adapt the mounting pole to some kind of conduit? I did some searching and mostly found utility pole installs where the wires just come out and go to the top of the transformer. I even saw one install document show just showing liquid tight conduit up the arm and then making a shepherds hook but that was with the power at the top of the pole not at the bottom. Am I just overthinking how one of these should be installed?
Fish_Stick is offline   Reply With Quote
Old 05-11-2018, 05:50 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 908
Re: This Shouldn't Be Hard - Pole Light
Can you post a picture or link on what you are trying to mount? Is the arm totally enclosed from the mounting point on the pole to the light fixture? Is it a factory unit?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-11-2018, 07:26 AM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
Getting the (switched) power to the fixture is always the tricky part.
How about if you post a few pictures of what you want?
Old 05-11-2018, 11:55 AM   #4
Rewards Points: 238
https://www.amazon.com/LED-Dusk-Dawn.../dp/B01BUNQS2O
https://www.amazon.com/TORCHSTAR-Pho...8HW54K3JZ2R4KN
Okay, not necessarily the models I'll be putting in but decent pictures in the links. So you can see in both the 1/2 ko for easy conduit but once it has the arm on it (first link) what should that be tied into? Thanks for the help!
Old 05-11-2018, 12:12 PM   #5
MarginallyQualified
... what should that be tied into?
I think you're holding the wrong end of the stick.
Where is the POWER for this (or ANY) fixture coming from?
Are you planning to install conduit on the outside of your house?
Run NM in the wall and out... maybe down from the attic?
Will there be switching somewhere?
mpoulton likes this.
Old 05-11-2018, 12:27 PM   #6
Rewards Points: 238
Power is coming from a gfci outlet mounted on the pole already. So the plan was to run liquid tight from the box and then attach it. THHN/THWN inside of the liquid tight. It's not the getting power to the point I'm having problems with it's that I can see when you flush mount the fixture the 1/2 ko is accessible and that's how you connect it. But when the arm gets mounted onto it you now cover that ko and only have the arm to run the wiring through. Reading various reviews the consistency of arm diameters is not great so adapting to a standard conduit could be a challenge. So maybe I'm missing something really simple but shoving the liquid tight up the arm just doesn't seem like the best practice.
Old 05-11-2018, 03:36 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 3,642
On the units I've seen, the mounting portion of the fixture allows you to run the wires either out the KO, or down through the tube the light is attached to. So in the pic you linked to, the wiring could either go out the KO or through the bent pipe. You'd want to run it through the bent pipe. Is your pole hollow? If so, then you probably want to run down through it and into the back of the receptacle box. Otherwise you need conduit up the side of the pole.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 05-11-2018, 05:09 PM   #8
MarginallyQualified
Gotcha. You have an actual pole for your pole light.
Sealtite. That's what you'll use from the add'l box you'll mount up high.
Exposed right into the fixture j-box.
Conduit on the pole surface down to the GFi Box. Pigtail the line side.
Old 05-12-2018, 01:19 AM   #9
Rewards Points: 238
Thanks, I'm going to have to head over to the store and see what these poles fit into. I really don't want to mount a 6x6 j box at the top of the pole. I am finding a few lights that the pole screws in like a flushmount so then the box on the light would still be accessible and then I would only have to run the liquid tight up the pole. Might be the easier option to go with that.
Old 05-12-2018, 01:22 AM   #10
Rewards Points: 238
Thanks. From the pictures I'm seeing it looks like once the arm gets inserted the ko is blocked. Running the wires down the tube to the box just seems so sloppy so I wanted it in conduit to clean it up but it seems like the options are limited on that. Going to check out a few models in store and see what they have.
Old 05-14-2018, 12:24 AM   #11
Rewards Points: 238
Yup, so this is so simple but I couldn't find good pictures of it. Went to the store and found one and right at the end of the arm there is a third knockout. I was visualizing the knockout on the bottom that once the arm is inserted it get blocked so you could only force the liquid tight up the arm and then just hope it didn't fall out. Thanks for the help and I'll go sit in the corner for a few on this one...
replace single pole light switch LindaM Electrical 7 09-02-2012 12:30 PM
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 08:50 AM
hard wire from light switch and outlet pennyeagle Electrical 0 08-27-2011 02:00 PM
single pole light switch bamadad33 Electrical 4 02-04-2011 09:59 PM
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 07:03 PM
