Should I Worry About Voltage Drop For This Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 08:09 AM   #1
Rewards Points: 162
Should I worry about voltage drop for this circuit?
I'm looking at installing a 15A circuit from my house down to my pier by the lake. The total run is looking to be about 125'. Planned on using 12-2 UF.
I'm not planning on running any heavy loads on this circuit - the shop vac for cleaning the boat will probably be the biggest load. Will voltage drop create an issue for this length?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 05-06-2012, 08:47 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
Based on your load you are good.
Use a GFCI receptacle rated weatherproof and an in service cover.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-06-2012, 10:44 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Well, using #12 for a 15A circuit you are already oversizing the wire.
Thing is, voltage drop @ 120v is much more sever than at higher voltages.
A shop vac is no small craw, especially a larger one. A 10A load @ 120V @ 125' recommends #10 wire. If the vac is medium to smaller, like 6-8A, then the #12 should be fine. You also have to remember, cheaper motors like a shop vac will run fine on lower voltages, like 105-110V. Even then the worst that will happen is you'll shorten the life of the motor. If the only heavier draws will be the likes of the vac I'd say the #12 is fine.
Old 05-06-2012, 11:12 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I agree with the others, #12 AWG, 125' run with a 10amp load will yield a 5% voltage drop, but that is well within limits of your application.
Old 05-06-2012, 11:41 AM   #5
J. V.'s Avatar
Rewards Points: 578
If you are digging a trench, I highly recommend you do something more. It is silly to dig a 125' trench for a 12/2 UF cable. JMHO.
The Following User Says Thank You to J. V. For This Useful Post:
Speedy Petey (05-06-2012)
Old 05-06-2012, 12:46 PM   #6
kevinp22's Avatar
Rewards Points: 260
i agree with JV but im mister overkill.
but think about future applications - and to do it all over again.
if it were me i would do a 20A circuit and run #10 wire or even a MWBC and give yourself 2 20A circuits.
kevinp22 is offline   Reply With Quote
Old 05-07-2012, 10:03 AM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,014
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
As inexpensive as conduit is now days it's nice to lay down a larger size than you need and have the option to upgrade later or pull new conductors if something happens to them without digging.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-07-2012, 11:06 AM   #8
J. V.'s Avatar
Rewards Points: 578
This is exactly what I meant. I would run more than one conduit also. Even if you just stubbed them up. Just my two cents.
efficiency voltage drop wire gauge jackwashere Electrical 6 02-18-2012 08:33 PM
household voltage drop pilottcs Electrical 3 12-10-2011 07:11 PM
Flickering lights on circuit with low voltage and line voltage bulbs davidwiesel Electrical 4 04-18-2011 08:54 AM
Will splice cause voltage drop? JPsAlias Electrical 6 05-19-2008 07:09 PM
Voltage Drop Manuel6 Electrical 1 01-16-2007 05:20 PM
