Should I Drill The Top Plates - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By jbfan
  • 2 Post By jbfan
Old 06-07-2019, 09:15 AM   #1
RustyRealtor's Avatar
Rewards Points: 711
Should I Drill the Top Plates
Hello Everyone,
This is probably a silly question, but here goes.
The house (one side of a duplex) I'm wiring is frame construction with brick veneer on a concrete slab. The stud wall framing is 2 or 3" from the brick, attached with brick ties. Some of the walls have a triple top plate.
Currently I have the Romex from the attic going over the top plates and down to the switches/receptacles. But of course I am second guessing myself and wonder what the inspector will say. I haven't stapled anything yet and it would be fairly easy to change.
Should I drill the top plates, or leave it as is?
Thanks Very Much,
Russell
RustyRealtor is offline   Reply With Quote
Old 06-07-2019, 09:47 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 794
Re: Should I Drill the Top Plates
Leave it as is.
MrElectricianTV likes this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 06-07-2019, 10:57 AM   #3
retired framer
Rewards Points: 18,478
There is a fire rated caulk fo those holes before you insulate.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 06-12-2019, 03:14 PM   #4
Rewards Points: 484
I would drill through the top plate and cover the hole with the same metal plate protector used to protect romex running through studs. Home theater installers go through triple top plates all the time. The original "electrician" was being lazy which is quite common.
Calson is offline   Reply With Quote
Old 06-12-2019, 06:36 PM   #5
jbfan's Avatar
Rewards Points: 794
No one was being lazy! The wires went over the top plate, behind the wall to the switches and receptacles. Happens all the time.
brric and MrElectricianTV like this.
Old 06-12-2019, 07:38 PM   #6
Rewards Points: 58
Is there sheathing between the studs and brick? I would drill centered in the studs and seal the holes after wiring.
Wiredindallas is offline   Reply With Quote
Old 06-13-2019, 11:35 AM   #7
Rewards Points: 34
I was wondering this too; has to be right, to separate/seal the air space between the brick and wall studs (best if plywood but could be cardboard thermoply).
The space can't be left open because of moisture and rodent issues.
The brick has to have weep holes at the bottom of it and if that electrical cable is run in that air space, mice will make their way through the weep holes and chew it up.
Assuming there is sheathing - (1) drill through the middle of the top plates and run the cable; (2) seal the holes with fireproof sealant; (3) attach metal plates across all areas where you drilled through top plates to protect from drywall/paneling nails/screws hitting cables.
DIYERSCOTT is offline   Reply With Quote
Old 06-17-2019, 11:58 AM   #8
Rewards Points: 711
Sorry for the delayed reply - my wifi is giving me problems.
There is no sheathing between the brick and studs.
My plan is to spray-foam the the brick walls, and then I want to paint the exterior.
What is a "progress inspection"?
Thanks,
Russell
Old 06-19-2019, 06:03 PM   #9
Contractor/Engineer
Rewards Points: 1,106
Ask your inspector, he's the one you want to make happy.
It's easy - tell him you want to make sure you comply with municipal code.
Any inspector I've had appreciates it when you make their job easier.
Domo is offline   Reply With Quote
