Shorter Wire Or Longer Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 08:48 PM   #1
hohadcr's Avatar
Rewards Points: 450
shorter wire or longer wire
i am adding a couple of rooms, and need to run new wires.
what is a better approach in general: use shorter wires and connect shorter wires using junction boxes to reach the load; or use long wires and no junctions?
thank you
hohadcr is offline   Reply With Quote
Old 03-07-2010, 08:58 PM   #2
The only junctions should be in a box
I make my runs to the 1st outlet or switch box
Then branch off from there
The less junctions the better...Zero junctions is best
Old 03-07-2010, 09:04 PM   #3
Learning by Doing
Leah Frances's Avatar
Here's a good issue for personal preference. I like long un-broken runs - less points for potential failure. But, I also try to plan JBoxes in strategic locations for easy later access.
I would recommend that you start planning your wiring diagram and post an image here. I got GREAT advice for the most efficient way to set up my installs.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-07-2010, 11:34 PM   #4
" Euro " electrician
frenchelectrican's Avatar
If the walls are open then go with longest one as possible to advoid any junction box along the run.
So basically what you are doing is making a homerun to first switch box or recetpale box depending on the circuit layout it will be.
Keep in your mind majotry of locations will be on 2008 NEC code so you will have to address with AFCI circuits in there unless you got the bathroom then the bathroom no it do not need AFCI at all but you will have to run a delcated 20 amp circuit to the bathroom this is very spefic on the NEC code
If you are from Canada the code will be slightly diffrent if so let us know one of the members here is from Canada he is famuair with the CEC requirement.
Merci,Marc
Old 03-08-2010, 07:21 AM   #5
hohadcr's Avatar
Rewards Points: 450
im in quebec, canada.
as it is for 1st floor, and everything is newly framed, i can access the basement and the open walls. so, homerun it is.
Old 03-08-2010, 07:48 PM   #6
Ahh in Québec that is nice area.
I can reply in both Engish and French if necessery.
Anyway just keep in your mind about the most recent code change in your area the best bet is check with your inspector for latest infomation related to the code.
{ French Verison }
Gardez de toute façon juste dans votre avis du changement de code le plus récent de votre secteur la meilleure option est le vérifier avec votre inspecteur pour dernier infomation lié au code.
Merci,Marc
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
