Sheathed Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2015, 08:32 AM   #1
Sheathed wire
I recently put in a sub panel about 12" away from my main panel. I am running circuit wire from the main to the sub panel and was curious if I need to keep the outer sheathing on the bundle of wire between the boxes. The only bare wire would be the ground wire but wasn't sure if I needed to keep the outer rubbery sheath on.
Davandar is offline   Reply With Quote
Old 10-19-2015, 05:33 PM   #2
Licensed electrician
Rewards Points: 3,766
Are you using conduit or cable? Cable needs the outer sheath intact until inside the box.
Davandar (10-19-2015)
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
Aluminum sheathed wire DoctorWho Electrical 2 07-26-2011 09:56 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
