Sharing An Outlet Box For A Splice - Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 10:20 AM   #1
Rewards Points: 97
sharing an outlet box for a splice - code?
is there any code violation if i have this situation (indoor)--
>a 2-gang outlet box, has two duplex outlets, one on breaker A, the other on breaker B, each being fed with 12-2 romex
AND
>> there is a cable splice (romex in <> romex out) and these cables are on a third breaker (let us say C).
ideally, i would not have one box being served by multiple circuits but this is a tiled wall so adding switch/outlet boxes will require a major surgery to the wall.
thanks
drgkjd is offline   Reply With Quote
Old 06-24-2010, 11:27 AM   #2
Licensed electrician
Rewards Points: 3,662
There is no problems with multiple circuits in the same box. you do need to tie all the ground together and also have enough cubic inch capacity for all the wires.
On a side note, I think I would label the back of the trim plate with all the correct circuit numbers that are in the box.
Old 06-24-2010, 08:21 PM   #3
Rewards Points: 97
thanks jim...
the double-gang box has an inch to spare in volume per code though it does not look that crowded and i follow the ground (ing) rules (no pun intended) seriously for my own safety.
good suggestion on marking the breaker-numbers
Old 06-24-2010, 08:30 PM   #4
As Jim mentioned, your box needs to be big enough for all those.
The minimum size box you need is 13 conductor allowances x 2.25 cu. in. for each = 29.25 cu. in. box space.
If using a plastic box, the box volume will be molded into the box.
If using a metal box, you would have the same required volume as long as the romex clamps have their actual clamping mechanism outside of the box (since it takes up mimimal space on the inside).
Willis
williswires is offline   Reply With Quote
Old 06-25-2010, 05:22 PM   #5
Rewards Points: 97
i am planing to use a carlon double gang 34 ci.
thanks
Old 08-04-2010, 12:02 PM   #6
Rewards Points: 91
I believe I have a similar situation with an outlet box to the right of my kitchen sink. Half the box is a duplex switch, the other half is a duplex receptacle.
I have a feed coming in from one circuit, providing power to a switched kitchen light and a switched outdoor flood light.
I have another feed from a different circuit feeding the receptacle, and then a daisy chain to a downstream receptacle.
So it has been said that its OK to have multiple circuits in one box, but what if everything is wired with the old cloth-covered NM with no ground?
debiasio is offline   Reply With Quote
Old 08-04-2010, 12:09 PM   #7
Still Ok to have multiple circuits in the junction box
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-27-2009 11:52 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
