Settle The Score.... - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 02:55 AM   #1
Question
Settle the score....
Ok so this is my first post on here and I am looking for some good feed back. The question is do I need a building permit and an inspector afterwards?
Scenerio:
We had a cape cod built with and unfinished upstairs. Now is time to complete the upstairs. I had the builder wire the first outlet in each room along with the bathroom and lights. The plumbing was roughed in but not completed.
I am going to allow a electican apprentis that is a neighbor to wire in the other outlet and the recess lighting. My wife believes we need a building permit and the inspectors after in order to be able to resale the house down the road.
What is the answer?
locknuup is offline   Reply With Quote
Old 11-27-2010, 06:13 AM   #2
Depending on your locality, you usually need a permit for any changes you make to the existing structure or utilities.
Old 11-27-2010, 06:41 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 710
Depends entirely on the locality. Call your local building department and ask. There is no way anyone on this forum can answer your question unless they live/work in your area and a familiar with the regs.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-27-2010, 08:22 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Yeah, it depends on your locality, but 95% sure you are going to need not only permits and inspection after, but also a rough-in inspection on the plumbing, electrical, framing and insulation. Then a final inspection once the job is 100% complete.
For finishing a complete second floor I would do it NO other way.
Old 11-27-2010, 08:42 AM   #5
the Musigician
DangerMouse's Avatar
"We had a cape cod built with an unfinished upstairs."
I'm confused.... how did you have a cape cod 'built' with no permits???
Regardless.... like Petey said, you need permits and inspections rough AND final.
I do realize that many people think they are a PITA and hate the inspectors but when you go to sell and none of the work has been inspected/approved........ well... you know. Listen to your wife.
DM
Old 11-27-2010, 08:54 AM   #6
I=E/R
a7ecorsair's Avatar
You've had responses on the permit side but I'd like to add this:
In MN you would be required to have a licensed electrician or be the home owner to do the remaining wiring.
a7ecorsair is offline   Reply With Quote
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
Can you score and snap Travertine ryan5068 Flooring 4 07-18-2010 11:34 PM
Husband and Wife About to Kill Each Other - Please Settle. 811Gibbon Flooring 16 04-19-2010 01:22 PM
Engineered flooring, will it settle???? rdmccaw Flooring 7 04-16-2008 04:31 PM
8 month old modular with flooring problems?? HELP!! SomewhereInNC Building & Construction 2 07-26-2006 11:11 PM
