DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Settle the score.... (https://www.diychatroom.com/f18/settle-score-87835/)
locknuup 11-27-2010 03:55 AM
Ok so this is my first post on here and I am looking for some good feed back. The question is do I need a building permit and an inspector afterwards?
Scenerio:
We had a cape cod built with and unfinished upstairs. Now is time to complete the upstairs. I had the builder wire the first outlet in each room along with the bathroom and lights. The plumbing was roughed in but not completed.
I am going to allow a electican apprentis that is a neighbor to wire in the other outlet and the recess lighting. My wife believes we need a building permit and the inspectors after in order to be able to resale the house down the road.
What is the answer?
Just Bill 11-27-2010 07:13 AM
Depending on your locality, you usually need a permit for any changes you make to the existing structure or utilities.
rjniles 11-27-2010 07:41 AM
Depends entirely on the locality. Call your local building department and ask. There is no way anyone on this forum can answer your question unless they live/work in your area and a familiar with the regs.
Speedy Petey 11-27-2010 09:22 AM
Yeah, it depends on your locality, but 95% sure you are going to need not only permits and inspection after, but also a rough-in inspection on the plumbing, electrical, framing and insulation. Then a final inspection once the job is 100% complete.
For finishing a complete second floor I would do it NO other way.
DangerMouse 11-27-2010 09:42 AM
"We had a cape cod built with an unfinished upstairs."
I'm confused.... how did you have a cape cod 'built' with no permits???
Regardless.... like Petey said, you need permits and inspections rough AND final.
I do realize that many people think they are a PITA and hate the inspectors but when you go to sell and none of the work has been inspected/approved........ well... you know. Listen to your wife.
DM
a7ecorsair 11-27-2010 09:54 AM
You've had responses on the permit side but I'd like to add this:
In MN you would be required to have a licensed electrician or be the home owner to do the remaining wiring.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
