Service Pole Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2015, 05:43 PM   #1
Rewards Points: 4
My wife and I have moved our double-wide on a piece of property that needs to have a service pole installed. After doing "amp loads" of research, I cannot decide what route to go. It is required to have a disconnect below the meter mounted on the pole. My question is what is the best method while keeping it budget friendly?
We have a house that has a 200 Amp main breaker which is about 100 feet from the pole. I am also putting in a 8x12 storage shed/temporary workshop that will have about 60 Amps and then I will be building a bigger workshop in the future with about 100 Amps. The breaker box in the house does not have any available spaces so I would like all three to be powered individually from the service pole. I've thought about doing a 200 Amp main breaker with feed through lugs which would go to the house and then have 60 amp and 100 amp breakers to the shed and future workshop. My question is does the feed through override the main breaker in the box? If I were to flip the main breaker, would the house remain powered or does the main breaker control the feed through and breakers? I appreciate all your help and feel free to ask any questions. Thanks
MKShultz is offline   Reply With Quote
Old 01-23-2015, 11:26 AM   #2
Rewards Points: 121
If you have a mobile home supply company nearby they sometimes sell the pole, weather head, meter socket and a main service disconnect breaker box as a pre-assembled unit. The one that I purchased has a 200a main breaker that when in the off position kill's power to all of the other breakers and the feed through.
jrepp44 is offline   Reply With Quote
Old 01-23-2015, 04:03 PM   #3
Rewards Points: 18,974
Budget or not great time to be contacting a real licensed electrician on this one.
Tags
disconnect , feed through lug , main breaker panel , subpanel
Help!! How do I add 100amp service to outbuilding/ Pole Building DJ12 Electrical 3 03-17-2013 09:32 AM
Upgrading/relocating main service shooter1951 Electrical 16 10-23-2012 11:47 AM
Need help installing new service and making old service a sub panel fightermage Electrical 9 09-26-2012 08:48 PM
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
