Service Box Location - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 07:40 AM   #1
What are some key guidelines to follow when selecting a location for the main electric service box in a home so it meets code and passes inspection?
Build is offline   Reply With Quote
Old 06-18-2009, 07:56 AM   #2
You need a location that is at least 30" wide unobstructed (the panel can go anywhere in the 30" it doesn't have to be centered) and at least 36" unobstructed in front of the panel to be able to stand and work on it and it can't be in a clothes closet. Others may have more info for you.
Plumbvoltage is offline   Reply With Quote
Old 06-18-2009, 10:33 AM   #3
liscenced electrician
Rewards Points: 540
36 in front of the panel or 36 in front of your side clearance too?
One question I do have is in my little service closet. I don't have a ton of space. My panel has plenty of clearance but my water heater will be a little in front of my low volt media panel. You will be able to get the cover off with a stubby on one side. Any problem?
jimmy21 is offline   Reply With Quote
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 07:45 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
