Series-parallel Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 09:29 AM   #1
Post
series-parallel circuit
Sir, can you help me solve for this series-parallel circuit problem and what are the steps in solving it. I'm trying solve for voltages, current and power in each part of the circuit. Although I know all the formula's (Ohms Law), when it comes to simplifying I got a hard time solving it.
Michael Kim is offline   Reply With Quote
Old 11-06-2010, 09:53 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,990
Start on the right side and combine the two resistors (r1, r2) in series. Then combine that value with r3 in parallel. Repeat.
The values are all setup so that you can do this in your head in about 30 seconds. The current through r6 is 4 amps.
The Following User Says Thank You to joed For This Useful Post:
Michael Kim (11-07-2010)
Old 11-06-2010, 10:24 AM   #3
Rewards Points: 308
Joed,
"Do not PM with questions that can be asked in a forum. I will not respond". Do people actually PM you that much? Just curious as I get maybe one or two PM's a year.
The Following User Says Thank You to J. V. For This Useful Post:
joed (11-06-2010)
Old 11-06-2010, 02:56 PM   #4
Super Moderator
joed's Avatar
NO not that often. I put that one time when someone did PM a follow up to a question and never changed it. Maybe its working that's why I'm not getting PM questions. I do respond to PMs. Just not to questions that should be asked in the forum.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 08:17 PM
parallel / series wiring question geetee Electrical 5 06-11-2008 02:42 PM
Diagram of dual hot water heater (s) in parallel not series having flow questions-- timlltt Interior Decorating 1 02-29-2008 03:01 AM
