Series Or Parallel? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 09:59 PM   #1
Rewards Points: 101
Series or parallel?
When running outlets on a circuit do I need to pigtail at each box or can I run the "in" to the top screws and the "out" to the bottom screws and Just continue on to the next box? Thanks, 1
1dumbquestion is offline   Reply With Quote
Old 12-31-2011, 10:02 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,442
Either way, and it is parrallel in either case.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
frenchelectrican (01-01-2012), Speedy Petey (01-01-2012)
Old 12-31-2011, 10:02 PM   #3
Licensed electrician
Rewards Points: 3,740
You can do either, except for the grounding conductors or if a multiwire branch circuit is involved.
Old 12-31-2011, 10:02 PM   #4
Mad Scientist
You can daisy-chain through each outlet as you describe, as long as it's not a multiwire branch circuit (Two circuits sharing a single neutral wire). You'll still need to pigtail the grounds, since you can't land two ground wires on the single ground screw.
Some people prefer to always pigtail the wires for receptacles, but it's just a matter of personal preference.
Edit: Wow, I guess we're all on the same frequency tonight...
McSteve is offline   Reply With Quote
Old 12-31-2011, 10:06 PM   #5
jbfan's Avatar
You guys don't have anything else to do either?
The Following User Says Thank You to jbfan For This Useful Post:
Old 12-31-2011, 10:14 PM   #6
Better half didn't want to go out with all the drunks and is watching Harry Potter. I never watched the first one so I would be so lost.
Old 12-31-2011, 10:30 PM   #7
Rewards Points: 6,652
Wouldn't household wiring branch circuits, actually be a Series-Parallel set of circuits, if you really broke it down.
Old 12-31-2011, 10:36 PM   #8
Rewards Points: 3,032
If the incoming and continuing hot wires are wire nutted directly to each other (with a pigtail to the switch or receptacle as applicable) then the corresponding neutrals must be similarly wire nutted directly to each other.
A switch is connected in series with the light or other "thing" it controls. (Feed hot wire to switch, other terminal of switch to light fixture, other terminal of light fixture to neutral of feed cable)
Receptacles and different light fixtures are never wired in series (power to gold terminal of one receptacle, silver terminal of first receptacle to gold terminal of second, silver terminal of second receptacle to gold terminal of third receptacle etc. then silver of last receptacle to neutral) except perhaps within some specialized portable laboratory test jigs.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 01-01-2012, 08:49 AM   #9
General Contractor
joasis's Avatar
Maybe you sparkies should explain a true series circuit, so someone doesn't get the idea they really want one. Remember the old strings of Christmas lights that if one bulb burned out, the string was dead until you located and replaced the bad bulb? Now.........
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 01-01-2012, 08:56 AM   #10
It is just as bad as those strings, that a bulb burns out, and half the string is dead. PITA.
Old 01-01-2012, 05:30 PM   #11
" Euro " electrician
frenchelectrican's Avatar
It was the same way I did dealt with old street luminaires with old school indenscnet bulbs and old school MV bulbs there were wired in series!! and to compound the issue is the voltage level on old school street luminares are insane high which most guys will say holy crap the last one I did dealt one city it have 120 MV bulbs from single source which it was 2400 volts !!!
so to find a bad bulbs was pain in butt but have to use the POCO grade high voltage tester to find the bad one ( it was cheaper and quicker for me to just replace all of them and be done with it.) then short time later it was converted to conventail HPS and got rid of the mess we have in that city.
Now only place I know still carry the true series luminaires is airport runaway luminaires and they have special shunt transfomer to run the luminaires so if one go out other stay on as far for the voltage itself that will varies a bit depending on the runway layout.
Merci,
Marc
Old 01-01-2012, 05:37 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Wouldnt using the screws on the plug make it a series?
Removing 1 of the screws would kill it past that point making it a series circuit,that being said i prefer to tail the wires in each box before plug maling it a parallel circuit.
unless my thinking has been wrong all these years
plummen is offline   Reply With Quote
Old 01-01-2012, 08:25 PM   #13
If you insist the metal strip on the side of the receptacle with the two screws is in series with the incoming wire and the continuing wire. And the various segments of wire daisy chaining from one receptacle to the next form a series circuit from the panel to the last receptacle on the line with one thing plugged in out there.
But we don't use the words series and parallel when we are talking about just the individual pieces of wire. Only when talking about the loads (lights, etc.) and controlling devices (switches, etc.).
The various things plugged into the daisy chained receptacles are not (had better not be) in series with each other.
Old fashioned streetlights connected in series often had a pair of fins at each location with a special disk (about a half inch in diameter) in between. The disk burned through and "shorted" when the lamp at that location burned out, keeping the rest of the lights on. Usually the fins were part of the lamp socket and the lamp and socket were extracted together and the lamp and disk replaced. (The socket assembly was usually held in since the parts were springy and was yanked out in a manner similar to many mini Christmas bulbs)
Series streetlighting allowed for thinner wires compared with parallel, although the insulation and insulators had to be rated for the higher voltage. In the heyday of incandescent streetlights and the start of the mercury vapor revolution a common voltage was 2400, taken from a 4160 volt 3 phase distribution system. One fairly thin (probably #8 minimum size to withstand snow) wire attached to the 2400 volt primary at one end of the street, daisy chained from one streetlight to the next, and was connected to ground at the other end of the street. This was a switched circuit with a photocontrol somewhere in it. Sometimes there was a regulator the kept the current (in amperes) somewhat constant and this actually prevented lamp burnouts from raising the voltage on the remaining lights and burning those out more quickly.
Old 01-01-2012, 08:36 PM   #14
plummen's Avatar
But the various things plugged into the daisy chained receptacles are not (had better not be) in series with each other.
Well would that not be the definition of a series circuit?
god knows ive replaced enough plugs over the years that were back fed or joined at the jumpers on side killing all the plugs downstream when one burned up.
In omaha theyve made you tail out all wires before the plugs as long as i can remember for this very reason
Old 01-01-2012, 09:20 PM   #15
Actually a Series circuit would be the example of a Switch Leg for a light, not a outlet in the middle of a run, that is pigtailed, or being used as a pass through.
dual water heaters: parallel or series?? broox Plumbing 33 12-19-2010 09:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Series or parallel runronno Electrical 29 07-17-2009 11:40 AM
Series or Parallel Outlets Bocolo Electrical 8 02-06-2009 08:40 PM
