Seprate Breaker Box And Outlets Vs. Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 12:02 AM   #1
Back Yard Warrior
Seprate breaker box and outlets vs. transfer switch
Would I be better off running a seperate Breaker box and installing outlets for a backup Generator or installing a transfer switch? Reasoning is the cost of a transfer switch (if I could get one right now) vs. the cost of a seperate box and outlets. And ease of setup should power go out when I am not home and wife has to connect.
TNTSchafhausen is offline   Reply With Quote
Old 09-06-2011, 12:23 AM   #2
Rewards Points: 1,016
Welcome to the forum!
Easiest and cheapest is a interlock for the main breaker.
Example: http://www.interlockkit.com/
____________
Vince
Old 11-16-2011, 08:54 AM   #3
I was looking into this too. Seems I would have to relocate the top 2 breakers as i seem to have the Siemens 4 handle top main breaker.
I assume then that you just need to be careful on what they turn on in the home so as not to overload the generator. I suppose I can also turn off breakers to rooms not in use. And I can maybe calculate the wattage per room of certain devices
Thx
desmo907 is offline   Reply With Quote
