Seperate Bedroom Circuits? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 01:44 PM   #1
I have a 2 bedroom house and the bedrooms are side by side. I need to update the wiring and was wondering if both bedrooms can be on the same circuit or does each bedroom have to be on their own circuit?
mxingislife is offline   Reply With Quote
Old 10-27-2010, 01:56 PM   #2
Rewards Points: 330
if easy to do split,if not they can be on same ckt if not heavly loaded.
oleguy74 is offline   Reply With Quote
Old 10-27-2010, 02:09 PM   #3
Can the outlets and lights be on the same circuit?
Old 10-27-2010, 02:21 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 948
Yes, and they need to be AFCI protected.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 10-27-2010, 02:40 PM   #5
Thanks jbfan. So the answer is yes, code is ok for both bedrooms to be on one circuit for outlets and lights, but it has to be on a AFCI breaker?
Old 10-27-2010, 03:56 PM   #6
Chicago, IL
Michael Thomas's Avatar
Consider also the potential loads in a modern bedroom: Exercise equipment, electric heaters, video and audio equipment, etc. - might make sense to put them on separate circuits.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-27-2010, 05:19 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Personally if I was in a position to run electrical for a house and the walls are open and easy to access, I'd run 2 circuits per bedroom, maybe even 3. 2 receptacle circuits, and one for lights. While you're there may as well future proof as much as you can. I'd also make sure there is an outlet near a window, for an AC unit if ever you decide to add a window one. Maybe have the window outlet be dedicated, the rest of the outlets on another circuit as one group, and lights on another circuit. The only down side to this is if it all has to be AFCI protected, then that increases cost by a lot. The cost of the extra wiring is insignificant at this point, when the breakers are like 50 bucks a pop.
Old 10-27-2010, 05:22 PM   #8
I run lights on one circuit
Then each bedroom has a dedicated circuit for outlets
Master bedroom has a 2nd circuit
These days I never share a circuit between bedrooms
Old 10-27-2010, 06:30 PM   #9
Just call me Andrew
Rewards Points: 1,032
I'd split off outlets and lighting. Keep in mind window a/c can use a decent amount. Do you plan to use them?
If you CAN split them, and you have plenty of space in the panel, split them. You will not be unhappy with more circuits later. But you will be unhappy with one big circuit that trips all the time.
Andrew
secutanudu is offline   Reply With Quote
Old 10-27-2010, 09:43 PM   #10
I have enough space in my panel to seperate the bedrooms. I live in northern california and the warmest it gets in the summer is in the low 70's so a/c is not needed. And each of the bedrooms only have one ceiling light fixture.
I'm thinking of running the romex under my house to access the bedrooms. Is this ok? Does the wire need to be protected with anything if it is ran under the house, or just secured to the framing/joists with romex staples?
Or if I decide not to do under the house can I run it along my house through rigid pvc conduit? Is that up to code?
Old 10-27-2010, 10:11 PM   #11
Can any animals access the underside where you will run wires ?
Some will chew on wires
Is it an enclosed space ?
Old 10-28-2010, 07:08 AM   #12
Licensed electrician
Rewards Points: 3,654
Under the 08 NEC you cannot staple cables that small under the joists. You need to run thru bored holes or on running boards.
Old 10-28-2010, 10:21 AM   #13
I have a concrete perimeter foundation and all vents and the crawlspace have screens, so animals shouldn't be able to get to it.
It looks like an animal was under the house in the past though because a lot of the insulation is ripped and hanging from the joists.
How many circuits for bedrooms? Clutchcargo Electrical 5 08-10-2010 09:40 AM
Amending Bedroom Circuits for Recessed Lighting FirstHome121 Electrical 2 03-29-2010 05:27 PM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
