Security Options For Exterior Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 12:28 AM   #1
Rewards Points: 95
Security options for exterior outlet
Hi,
This seems like the best resource to answer this question.
I have more outlets than I need on the exterior of my home. They are all weather-spring covered GFI outlets with a bezel on the vinyl sides of my home.
I have some large trees and I may eventually install a motion light and/or camera in one of the trees looking back at the home.
Instead of drilling through my basement I was wondering if there is an exterior box available I could swap out that would give an attachment for rigid conduit in which I would run the (basically tamper-free) electric, underground until near the base of the tree. Drawing below...thanks!
bergerdude is offline   Reply With Quote
Old 10-08-2010, 06:29 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 958
They do make extension boxes that you can use.
The are open on the front and the back, and allow you more wiring room and to add conduit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 10-08-2010, 06:40 AM   #3
Seems like one must spend some more bucks on this to complete...
Turbo56 is offline   Reply With Quote
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 02:30 PM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
Recommendations needed for high security entry doors wolfsberg74 Building & Construction 2 05-03-2010 09:09 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
The Security Guy TheSecurityGuy New Member Introductions 3 09-29-2008 10:17 AM
