Securing A Wire Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 07:03 PM   #16
Inspector/Instructor
codeone's Avatar
Also 334.15 for exposed work.
(B) Protection from Physical Damage. Cable shall be
protected from physical damage where necessary by rigid·
metal conduit, intermediate metal conduit, electrical metallic
tubing, Schedule 80 PVC conduit, or other approved
means. Where passing through a floor, the cable shall be
enclosed in rigid metal conduit, intermediate metal conduit,
electrical metallic tubing, Schedule 80 PVC conduit, or
other approved means extending at least 150 mm (6 in.)
above the floor.
This is also NOT new for 2008.
codeone is offline   Reply With Quote
Old 01-08-2010, 07:04 PM   #17
Rewards Points: 6
So let me get this straight. NM can only be run in conduit in unfinished basements and crawl spaces or only with short sections of conduit to protect the wire. Is this correct? Scuba Dave said that you can use larger conduit to run NM in. Is he correct with this or not.
Its been a while since I have looked through the NEC handbook. I need to get a current edition.
paul100 is offline   Reply With Quote
Old 01-08-2010, 07:09 PM   #18
Online NEC 2008
http://nfpaweb3.gvpi.net/rrserver/br...NFPASTD/7008SB
Old 01-08-2010, 07:12 PM   #19
codeone's Avatar
Originally Posted by Paelectrican View Post
Well apparently my instructor was a little off when he told us that!! Thanks for the information.
Maybe not totally The 2008 also has a new rule about conduit installed in a wet location. The interior of a conduit in a wet location is to be considered a wet location. NM cable is not allowed in a damp or wet location, also an underground or underslab conduit is considered a wet location. NM (romex) would not be allowed in these conduits.
You could have misunderstood or forgotten one of the parts he told you. Then again maybe not.
Give him the benefit of the doubt or at least ask to clarifly.
Old 01-08-2010, 07:13 PM   #20
codeone's Avatar
Look at all my Posts. Youll see its ok in other places also.
Old 01-08-2010, 07:16 PM   #21
Yeah I'm already finished with school; however, i understand what your saying. That's why you never stop learning.
Paelectrican is offline   Reply With Quote
Old 01-08-2010, 07:19 PM   #22
Rewards Points: 6
Originally Posted by Scuba_Dave View Post
Thanks Scuba but for some reason my browser wont allow me to view that.
Old 01-08-2010, 07:22 PM   #23
codeone's Avatar
Even though I still have more schooling to upgrade some of my inspection certifications (Electrical Im finished with I can go no higher with certifications and liscenses in that field my speciality) Im working on Building ,Plumbing, Mechanical, and Fire, We still have continuning ed and then there are the Code changes every year. You always can and have to learn if you want to continue to grow and not vegitate.
Old 01-08-2010, 07:26 PM   #24
Well I've got a long way to go and try to learn everything i can from people with more know how than i. As i try to teach those with less knowledge. Absolutely right. Am a member of several forums to learn from others.
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
3 wire to 4 wire question macmouse Electrical 24 05-01-2008 05:34 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
