Second Ground Rod Near Object That Is Higher In Yard? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Oso954
Old 07-26-2019, 10:50 AM   #1
Rewards Points: 38
Second ground rod near object that is higher in yard?
I'm building a deck with an 8 foot observatory dome on it in the back yard.
I'm running 10-3 with a ground wiring directly from the main panel to a 2 breaker sub panel which will go inside the dome (which at the meter there is already a ground rod).
I'm hearing differing opinions on the ground rod situation. My one electrician is saying i should put a dedicated rod up by the observatory pounded into the ground there (8 foot copper with 6awg copper wire coming off that to ground somewhere on the deck/dome).
Others say only one in the system is needed or that this wont help particularly with a lightning strike if one were to occur?
Any thoughts out there?
Thanks in advance
markm75 is offline   Reply With Quote
Old 07-26-2019, 11:41 AM   #2
Rewards Points: 256
Re: Second ground rod near object that is higher in yard?
Follow the electricians advice. He know's what he's talking about. I believe it is electical code to ground a sub panel seperately. If you ever need the second ground you'll be glad you have it. What's a few dollars compared to damage, injury, or worse.
lug-nuts is offline   Reply With Quote
Old 07-26-2019, 11:49 AM   #3
Rewards Points: 38
I agree, but i've seen it said that its "bad" to do this, unsure why though, so i was curious.
Old 07-26-2019, 12:05 PM   #4
Rewards Points: 38
Though many say having that rod wont dissipate a lightning strike.
Old 07-26-2019, 12:30 PM   #5
Oso954's Avatar
Rewards Points: 1,264
I think you need to ground rod and ground wire for the subpanel in the dome. (This is in addition to the ground wire from the main panel.)
The dome is very likely to be ruled a structure separate from the house.
As far a grounding “the deck/dome”, I don’t know why someone would suggest that. (wooden deck, plastic Nexdome)
Oso954 is online now   Reply With Quote
Old 07-26-2019, 12:36 PM   #6
Rewards Points: 38
As far a grounding ďthe deck/domeĒ, I donít know why someone would suggest that. (wooden deck, plastic Nexdome)
Ah so in other words, since is a nexdome on a wood deck, the lightning implication is minimal and the ground rod may just be added grounding?
Old 07-26-2019, 01:22 PM   #7
Oso954's Avatar
The ground rod would be additional grounding (required) for the electrical in the detached structure. (Assumes your AHJ would rule the dome detached)
FrodoOne likes this.
Old 07-27-2019, 04:56 AM   #8
Rewards Points: 2,854
Thanks in advance
I suggest that you view (at least the first 30 minutes of) this video.
It explains the several reasons for Ground Rods at the main panel and the need for another Ground rod at and Sub-Panel.
(Note that the connection to any Ground Rod(s) should be as direct as possible without any loops or unnecessary bends.)
FrodoOne is offline   Reply With Quote
Old 07-27-2019, 07:23 AM   #9
Naildriver
chandler48's Avatar
Rewards Points: 1,830
The separate ground may be required by the AHJ, and is the norm for a sub panel. Not sure why it being higher on the grade would matter. Just for information, a lightning strike can supply a large city with electricity for a good while, so don't think a #6 grounding wire will dissipate one. The grounding rod is required for normal grounding purposes. Nothing in today's world will help a lightning strike.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-27-2019, 11:05 AM   #10
Rewards Points: 74
If you only running for two circuits - is the panel even necessary, and therefore the grounding rod?
This is more of a question for experts than advice - I thought it was acceptable to run a MWBC to a detached building as long as there is a disconnect.
tribe_fan is online now   Reply With Quote
Old 07-27-2019, 02:22 PM   #11
Oso954's Avatar
Itís not a place to cheap out on electrical.
Personally, Iíd be running a 3rd circuit (dedicated) just for the scope.
