Seal Gap Between Drywall Ceiling And Recessed Lighting Can - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 05:16 AM   #1
Seal Gap Between Drywall Ceiling and Recessed Lighting Can
Greetings,
I am going to be sealing up my attic and need advice on how to seal the gap around the rim of my recessed lighting cans and the ceiling drywall below. I thought of using great stuff but it's website indicates it should not be used around lighting fixtures. I have installed 9 Halo Air-Tight Recessed Cans. Should I use a caulk, if so what kind?
Alex
albasaurus is offline   Reply With Quote
Old 07-10-2010, 05:18 AM   #2
Seal Gap Between Drywall Ceiling and Recessed Lighting Can Rim
2 threads on same issue merged
Please only start one thread
Old 07-10-2010, 06:04 AM   #3
Something like DAP siliconized latex should work, but the interior trim piece should provide the needed seal, unless the hole was way too big.
Old 07-10-2010, 06:17 AM   #4
Any specific kind of silicone latex caulk, temp rating?
Old 07-10-2010, 06:23 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
If they are Air-Tite cans no sealant is necessary. They already have a foam ring gasket around the hole.
Old 07-10-2010, 07:20 AM   #6
This is a 1/8" gap between the drywall mud and the can. I don't see a gasket.
Old 07-10-2010, 07:22 AM   #7
Rewards Points: 2,800
Is the can itself free of unused screw holes, slots for adjusting of the lamp position, etc? If not, then you need not bother sealing around the rim.
Even with an incandescent lamp in the can, the rim does not get that hot. Most of the heat is at the other (high) end of the can.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 07-10-2010, 07:26 AM   #8
Rewards Points: 1,192
Then mud the gap to be Code Compliant.
bobelectric is offline   Reply With Quote
Old 07-10-2010, 07:27 AM   #9
The gasket is between the frame and the back side of the sheetrock.
If there is no gasket then it is not an Air-Tite can.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Ceiling Fan and Recessed Lighting with No Attic Access...Ugh. caps84 Electrical 1 08-06-2009 10:09 AM
Recessed lighting & ceiling fan installation advice SillySally Electrical 5 08-05-2009 10:07 PM
Recessed Lighting For Ceiling Tiles?'s Stargazer Remodeling 6 09-04-2007 09:42 AM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
