Sched 80 Vs. Sched. 40 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 04:29 PM   #1
Rewards Points: 129
Sched 80 vs. sched. 40
(Thank you, Robpo -- from another thread.)
I thought sched. 80 was for better protection against possible physical abuse. How does sched 80 handle sunlight better than sched 40? Aren't they both formulated to protect against UV?
Daneel is offline   Reply With Quote
Old 06-28-2014, 04:41 PM   #2
Rewards Points: 3,396
I would feel better with a piece of lead or steel pipe rather than pvc if I was going to get physically abused.
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
plummen (06-28-2014)
Old 06-28-2014, 04:56 PM   #3
Rewards Points: 18,990
Same material, different wall thickness.
Hope your talking about gray PVC.
White is not rated for direct sunlight.
Old 06-28-2014, 06:05 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,814
Schedule 80 offers protection to the wires and schedule 40 does not.
This is according to code.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Daneel (06-28-2014)
Old 06-29-2014, 02:11 PM   #5
thank you.
You know.
Protecting against physical damage. When I do a service in a driveway area, it's tough (maybe impossible) to get fittings and condulets in sch. 80 so I do it in emt.
Burns my buns as I drive around and see hundreds done in sch 40.
Thank you for letting me vent. I feel better now.
Not.
MTN REMODEL LLC (06-29-2014)
Old 06-29-2014, 03:08 PM   #6
Licensed electrician
Rewards Points: 3,862
EMT is not listed against physical damage.
Old 06-29-2014, 03:53 PM   #7
Rewards Points: 370
I prefer not to be abused by any type of pipe...
petey_c is offline   Reply With Quote
Old 06-29-2014, 05:22 PM   #8
Yet 230.50 (B)(1) lists it for protection for service entrance cables where subject to physical damage.
I think I read somewhere it wasn't rated where subject to "severe" physical damage.
Old 06-29-2014, 05:29 PM   #9
yep.. emt 358.12(1) not permitted where subject to "severe" physical damage.
Old 06-29-2014, 07:03 PM   #10
Thanks.
Old 06-29-2014, 07:17 PM   #11
Thanks.
You're welcome.
And again I must thank you and the others here.
This place keeps me learning.
3/4" sched 40 PVC fill collegetry Electrical 8 09-12-2013 03:00 PM
