Sanding Of Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 09:17 AM   #1
Sanding of wires
Whenever I replace a receptacle or switch, etc, I have made a habit of sanding the bare portion of the wires to remove oxidation. Is that a good idea, or do I run the risk of removing enough copper to essentially reduce the current carrying capacity of the wire. I definitely avoid over-doing it and only use a very fine sand paper.
Thanks,
Marc
mkrawitz is offline   Reply With Quote
Old 04-28-2010, 10:50 AM   #2
'Nobody' does it so it is apparently not necessary, except for soldered connections. Perhaps the screws cut through the oxide.
Old 04-28-2010, 11:12 AM   #3
Licensed electrician
Rewards Points: 3,670
If the conductors look dark or oxidized I cut back to new surface or a quick rub with some fine sandpaper. I don't think reducing the ampacity is hurt by this and the resistance is probably lowered due to a clean surface.
Old 04-28-2010, 11:13 AM   #4
I have lightly sanded wires in the past to clean them up
It shouldn't effect the wire....unless you use a power sander
Old 04-28-2010, 04:21 PM   #5
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I have also done it but i think it was more for me to know then the real need to do it.
Big N8 is offline   Reply With Quote
Old 04-28-2010, 06:16 PM   #6
'Nobody' is turning into a small crowd.
Does the NEC weigh in on this practice? High contact resistance can be a safety issue.
Or is it 'good practice', like putting the outlet ground hole on top?
Old 04-28-2010, 06:27 PM   #7
I only do it on older wires & if they look discolored
And its only a very light sand - maybe 200-400 grit ?
If a lot of spare wire I will also sometimes just cut the bare piece off & strip more
Newer wiring I do not bother at all
Can't say as I have ever read anything in the NEC regarding it
Old 04-28-2010, 07:14 PM   #8
the Musigician
DangerMouse's Avatar
I would think steel wool would do a far better job and remove way less copper....
DM
Old 04-28-2010, 11:56 PM   #9
Union Electrician
goose134's Avatar
DM
Good call!
goose134 is offline   Reply With Quote
Old 04-30-2010, 12:13 AM   #10
" Euro " electrician
frenchelectrican's Avatar
DM
It do the same thing with alum conductors as well but go easy with it they will really grout it.
Merci,Marc
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 08:11 AM
Confusing Chandelier Wires Burnsy Electrical 21 02-22-2009 04:29 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
