Safely Wiring New Recessed Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 09:26 AM   #1
I am planning remodeling my kitchen. I plan to call an electrician for some of the most complex wiring, but, a couple of the jobs are more or less typical DIY projects I might tackle. In the demo of the old kitchen, I see that the old flourescent light tubes are wired from a single circuit which uses uses a 20 amp breaker, with a 12/2 homerun through metallic conduit. The easiest thing for me would be to connect 14/3 Romex from the first junction box to each of the 6 recessed lights (75 watt max each.) The reason for asking this question is that I know that this might not be legal or safe at all, but, was wondering if there is a way to make it safe and legal. Would the following things make this safe/legal? First, connect the Romex grounding wire to the grounding screw in the original metal junction box. Second, replace the breaker with a 15 amp breaker. I am concerned that this might allow the 14 guage wire to heat up, but, thought that the 15 amp breaker might solve the problem. Again, I admit I am not electrician and that is why I am asking before making a dangerous mistake. Any help would be greatly appreciated.
Destin is offline   Reply With Quote
Old 03-17-2010, 10:34 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Any reason not to continue using #12?
Replacing the breaker is the only safe and sure way to not overload the #14.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
Destin (03-17-2010)
Old 03-17-2010, 04:07 PM   #3
The only reason isn't a good technical reason. I have almost a full 100ft roll of 14/3 Romex left over from another project. Thanks for the help.
Old 03-17-2010, 09:04 PM   #4
If the circuit is already 20a then continue to use 12-2
Sell whats left of the roll of 14-3
wiring several recessed lights from 1 switch raineydr Electrical 14 03-15-2010 08:52 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
