Running UF In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2015, 09:50 AM   #1
Rewards Points: 14
Running UF in conduit
I've seen conflicting post on weather or not this is possible .
Does it matter if its rigid, emt, or pvc ?
At my local home depot the UF cable bought in a 100ft roll is about 30% cheaper than the THWN.
oddball is offline   Reply With Quote
Old 09-11-2015, 09:55 AM   #2
Licensed electrician
Rewards Points: 3,840
UF can be sleeved to protect it from damage. If that is the purpose only certain types of conduit qualify as protection.
Sizing rules must be followed. You will not enjoy pulling a stiff cable into the conduit.
Old 09-11-2015, 10:18 AM   #3
Rewards Points: 299
It can be done. It's a pain in the ass.
Syberia is offline   Reply With Quote
Old 09-11-2015, 11:16 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Try pricing the THWN & UF at an electrical supply. HDs pricing on cut wire and short rolls is high.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Running NMD-90 wires through a conduit Horseonaboat Electrical 14 11-14-2013 06:53 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Running conduit from basement to the standalone garage sheslostcontrol Electrical 10 10-23-2010 12:22 PM
Conduit for wiring running thru concrete foundation? Oxymoron Electrical 11 12-05-2009 07:26 AM
Running Conduit in new basement framed walls tben Electrical 3 12-10-2004 11:14 PM
