Running TV Cable From Garage To Upstairs - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2015, 12:56 PM   #1
Rewards Points: 373
Running TV Cable from Garage to upstairs
When I moved in the house there was cable running from the finished garage to the upstairs office. all that was done was a hole drilled into the drywall ceiling in the garage thru the subfloor and carpet in the room above about 3 inches from the wall? I am re-carpeting and would like to move the cable to a wall outlet.
If I have this right can't I just drill another hole thru the drywall ceiling in the garage 4.5 inches closer to the wall which should go through the bottom plate. Then install a remodle box in the drywall and pull the cable thru that and install one of thoe cable plate over the box?
Sound easy but have never done this before.
thanks!
titan7 is offline   Reply With Quote
Old 01-28-2015, 02:09 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,890
I think I would cut the hole in the wall for the box first. Then you could use a long bit go from above through the hole.
The Following User Says Thank You to joed For This Useful Post:
titan7 (01-28-2015)
Old 01-28-2015, 02:26 PM   #3
Oso954's Avatar
Rewards Points: 1,274
How do you plan to fire seal the hole in the garage ceiling ? (existing and new)
Oso954 is offline   Reply With Quote
Old 01-28-2015, 02:38 PM   #4
Rewards Points: 373
Didn't think of that. How is that done?
Old 01-28-2015, 03:25 PM   #5
Oso954's Avatar
Assuming the hole is not huge, a fire barrier caulk would work. I would use 3M Fire Barrier CP 25WB Caulk or an equivalent.
While I had it in hand, I would look for other penetrations of that ceiling or the shared house wall and caulk those as well. It can be surprising how many of the penetrations are not properly sealed.
The Following User Says Thank You to Oso954 For This Useful Post:
clw1963 (01-28-2015)
Old 01-28-2015, 03:49 PM   #6
Rewards Points: 373
Thank you!!
The Following User Says Thank You to titan7 For This Useful Post:
Oso954 (01-28-2015)
Old 01-28-2015, 10:07 PM   #7
Msradell's Avatar
Rewards Points: 1,006
Actually since this box will need to be used for television cable you don't even have to use a true electrical box, you can just use a low-voltage frame like this: http://www.lowes.com/pd_132831-295-5...box&facetInfo==
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-29-2015, 10:28 AM   #8
Rewards Points: 2,600
there's also the fire rated foam in can (http://www.homedepot.com/p/GREAT-STU...7?N=5yc1vZbaxj)
concrete_joe is offline   Reply With Quote
Old 01-29-2015, 01:36 PM   #9
Oso954's Avatar
Try putting a match to Great Stuff Fireblock.
Its ignition temp is 240 Degrees.
Here is an article on it.
http://forums.finehomebuilding.com/b...lock-watch-out
It will NOT maintain the rating on a fire wall or ceiling.
Running 220 line to Garage - NJ GeorgeNS Electrical 13 06-05-2014 07:27 PM
Running NM cable through studs? RinSF Electrical 19 04-02-2012 08:13 PM
Running New cable for TV, help Ckb3216 Electrical 13 11-24-2011 05:12 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 06:47 PM
Water running from Driveway into Garage. CAD Building & Construction 5 06-17-2010 07:30 PM
