Running Romex Through 1st Floor Joist Cavity - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2014, 01:11 PM   #1
Rewards Points: 398
Running romex through 1st floor joist cavity
Want to add a few recessed lights in my first floor office - using the joists to my advantage I was going to run romex through them within the cavity to chain them together.
Is there any issue with running the romex down the cavity without actually stapling it tight along the joist? Trying to limit drywall patching where I can
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 12-27-2014, 01:18 PM   #2
Licensed electrician
Rewards Points: 3,840
Cables that are fished are not required to be secured like new work.
Jump-start (12-27-2014)
Romex in Conduit Outdoors starrapido Electrical 3 11-27-2012 10:00 AM
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 07:40 AM
A Couple of Questions About Running Romex Wire Near Utilities toobhed Electrical 4 08-26-2011 08:15 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 04:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
