Running ROMEX Into Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-05-2009, 07:20 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Scuba_Dave View Post
If it's only 3' then I see no point in violating code by removing the romex
If you need more room run another 3' section of conduit
Most inspectors will nail that one fast { few may let it slide } the key issue is cooling or bunding effect and I know from either UL lab or one of other source say if bunding like you put in the conduit that we can call them bundling and the restrection start take in effect once you get the conduit over 24 inches the derating will rule it so that one thing you have to keep in your mind with any conduit or bunding NM's once you get over 24 inches that will get ya but under 24 inches they will not pick on that at all.
That one thing when I do service upgrading I try to keep it short as possible if you have drop ceiling or attic if under 24 inches ya can stuff it.{ but not crazy to do it }
Merci,
Marc
Running conduit for a pool light KyMike Electrical 12 06-17-2009 03:02 PM
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 01:06 PM
Why not Romex in Conduit? Mr Chips Electrical 3 11-08-2008 09:58 AM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
