Running A New Line For Stove In Conduit On Outside Of House - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 02:57 PM   #1
Running a new line for stove in conduit on outside of house
Hi
New to posting but have used forums extensively for tips. Would appreciate input on the following:
Need to run a new line for induction cooktop (previously gas). Basement all finished, and would be difficult to run indoors. Cooktop and panel are on same side of house, ~ 45ft run required (with 3 x 90degree bends, to go around a side door).
The plan is to use PVC conduit, all above grade. Need 8-3 (40A cooktop, though have considered putting in 6-3 for future proofing??)
I have read conflicting accounts of most appropriate wire: romex, romex UF-rated, or THHN/THWN single wires.
Advice on best wire (and appropriate size PVC) greatly appreciated.
I'm in Canada, so will be exposed to rain and snow (as well as our own building code, but if i can get a practical answer i can then confirm it conforms to local code.)
Thanks in advance
nocsec is offline   Reply With Quote
Old 12-30-2010, 03:39 PM   #2
Running romex in pipe is difficult, and might not be legal. If it's a continuous pipe run, from one box to another, just use 'loose' wire. THHN would be my choice. Schedule 40 you can use 3/4, schedule 80 PVC you probably want to go up to 1. I'd suggest the 1" Either way, you have a handful of bends and it'd be a lot easier, and hardly any more money.
Also, if you're thinking of future upgrade, run 4 wires. 2 hot, neutral, and ground, I'm not sure which you're running, but it's nice to have the neutral if, later, you get a stove with 120V controls that needs one. Had that problem a *lot* with dryers around here. (4 wires will still fit in 1" either way.)
JPraski is offline   Reply With Quote
Old 12-30-2010, 03:53 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
romex cannot be run in conduit outside. Thhn is cheapest when used with pipe. PVC does not fair well above ground, so I would recommend EMT and paint, but your choice. PVC must be supported in horizontal runs ~36".
What about running thru attic?
Saturday Cowboy is offline   Reply With Quote
Old 12-30-2010, 04:12 PM   #4
Thanks. The question re upgrade would be if we wanted to put in an under counter oven down the road... (Ie to have 6oamp capacity Its currently on the opposite wall but I never know what my wife might want 5 yrs from now. Maybe the conduit could take more wires later in the (probably unlikely) even we want them?
Old 12-30-2010, 04:18 PM   #5
3 storeys so attic not practical
What do I do with thhn going to panel (4 ft from exit wall) -- junction to romex or run the thhn right inside to panel (protected of course)
Seems like most people use pvc around here; but will look into metal option too
Old 12-30-2010, 04:28 PM   #6
You mean, through the building, and then inside to breaker panel?
It must be protected. Running pipe on the inside is fine, and use the same wire, or you could put in a junction box and use NM cable. Either would work, but I'd prefer pipe for a few reasons. Aesthetics mostly, I guess, but buying another type of wire and box and blah blah for just 4 feet is kinda a PitA. A few extra feet of pipe left over from outside, and a hub to hook on the box is a lot easier IMO. Note you can't use the wall as a raceway- you need to transition to romex outside, or put the pipe through the wall. Not too big of a deal, just a little bigger hole.
Old 12-30-2010, 04:31 PM   #7
Scared Electrician
THHN must be run in conduit. so you can pipe all the way or install jbox and change to another wiring method(romex for example).
Old 12-30-2010, 04:39 PM   #8
Seems you are running the conduit outside
As such it has to be THWN for outside use
Old 12-30-2010, 04:50 PM   #9
Thanks. Yes I think we are on the same page. Panel is 4 ft from foundation wall where wire will exit building. Run on exterior brick wall to back part of house (same wall) then enter through brick directly beneath cooktop for hookup.
So hole in briclk needs to be large enough to accomodate pvc if I understand correctly.
Any thoughts on running 6 vs 8 g to have extra capacity?
And to clarify -- thhn and not thwn appropriate for this application
Thanks again for prompt and helpful responses.
Old 12-30-2010, 06:05 PM   #10
Scared Electrician
Most wire stocked at supply houses or big boxes is dual rated THHN/THWN
Old 12-30-2010, 06:10 PM   #11
Scared Electrician
just to be sure you are not planning on running wire free once under the cooktop.
yes i recommend an LB just outside.
what do you foresee needing? remember you can't have more than one appliance on one branch circuit.
Old 12-30-2010, 07:02 PM   #12
thanks
will have junction box right on entry under cooktop (so no loose wires)
the only forseeable addition (which i doubt will ever happen) would be to move the undercounter oven from the opposite wall (where it has its own feed) to underneath the cooktop. based on the code book i have reviewed, it is allowable to run oven and cooktop off of one feed (65amp would be required) as long as they are in proximity they are considered like one appliance... (i am pretty sure on this, but would definitely clarify if i were ever to pursue in the future)
Old 12-31-2010, 07:14 AM   #13
Scared Electrician
it would be cheaper to upsize your conduit so that you could add another circuit later.
Old 12-31-2010, 08:45 AM   #14
ok -- thanks.
checked with supply houses, and the wire that is generally available is T90
is this suitable?
if so, is 1inch PVC suitable, or bigger/smaller recommended?
Thanks again
Old 12-31-2010, 08:52 AM   #15
I agree with that you should make sure the conduit is large enough, it's cheap. Going with larger wires is a good idea, the only drawback is expense.
If I were doing it at work, no brainer, extra cap for sure. If I were paying for it, I'd likely put the larger in too, I'd need to price, but it's not that much more copper. It saves a lot of possible headache later, and is not one iota more work. But then, I'm the sort who overdoes everything, I'll pull #12 for lighting feeds just in case I might want to change things around later and use them for 20A outlet feeds.
The questions are: How much money is it worth to you, to never use it? And how much money is it worth to you, to not need to do it again? Not only pull it all over again, but buy all new wire, instead of just paying the difference? Chances are you'd never use the old wire again, unlike some of us. It'd be scrap if you redid things and a total loss, as opposed to a partial loss (of the extra size copper only) if you never used it.
Running pex from the meter to the house, but what about above ground? chayce Plumbing 4 11-09-2010 06:36 AM
Running conduit from attic to garage. raptor_demon Electrical 16 01-25-2010 09:12 PM
running electric from house Tradesman14 Electrical 3 01-14-2010 11:16 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Running Conduit in new basement framed walls tben Electrical 3 12-10-2004 11:14 PM
