Running New A/c Line - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 08:59 AM   #1
Running new a/c line
The wire would have to follow this path:
-from the panel into the attic
-down an interior wall inside the garage
-go through the block wall
-run down conduit along the wall 5 or 6 feet to the disconnect
What is the best/proper way to run the wire? I was going to run the whole line in NM wire, but I am not sure if I can sleeve NM cable that far. I would like to keep it all in one run, but I can add a junction box to either the outside or inside of the garage and run THHN or THWN wire the rest of the way to the disconnect.
pomelo is offline   Reply With Quote
Old 03-10-2010, 09:15 AM   #2
Master Electrician
Rewards Points: 5,082
Technically(code wise) NM cannot be installed in wet loctions even when it is sleeved. UF cable can be sleeved and used in wet locations.
Depending upon your conductor sizes, your junction box plan may be the best.
For sleeving I would recommmend using liquidtight non-metallic flexible conduit.
brric is offline   Reply With Quote
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Natural gas line????? figs Plumbing 1 06-14-2009 01:13 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
Running a natural gas line Roger General DIY Discussions 2 02-27-2009 07:42 AM
