Running Multiple Wires Thru Double Wall Plate - Alternatives? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2017, 03:28 PM   #1
Rewards Points: 86
I am trying to find an alternative for drilling multiple holes in a double wall plate to run wires along (exposed) ceiling beams. What are the options?
1. Can I use LB In a place where a stud connects a top wall plate to run wires from "behind the drywall"? The holes in this case will be drilled in a drywall.
2. If drilling thru a double wall plate is the only option, is there I can enforce it? I saw a photo with a metal bracket (approx 8"-12") attached to a wall plate where it was perforated. Not sure if this is approved nor where to buy it.
3. Any other thoughts?
Thanks!
Jack_Zzz is offline   Reply With Quote
Old 09-12-2017, 04:32 PM   #2
retired framer
Rewards Points: 1,284
Re: Running Multiple Wires Thru Double Wall Plate - Alternatives?
We would like to think joists are directly above the studs so there is no worry but if that isn't the case and you are worried about it just add another stud under what needs to be supported. The plates across the front is when the holes are close to the surface and you want to make sure drywall screws don't get into them.
Old 09-12-2017, 07:44 PM   #3
Licensed electrician
Rewards Points: 3,678
Multiple cable through a double plate should not be an issue.
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 07:46 AM
Running conduit through exterior wall then underground Michaelrj9 Electrical 7 03-20-2016 03:20 PM
Shower install on outside double wall construction boerssd Plumbing 0 01-16-2012 02:02 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
New wall oven has 4 wires wall has three hobiecatman Electrical 5 10-05-2010 07:19 PM
