Run Wire Into A Chain Link Fence Post ? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2015, 09:09 AM   #1
Rewards Points: 14
Run wire into a chain link fence post ?
Hello all
i'd like to put a driveway light ontop of a 6' chain link gate post
can i come up from under ground next to it and drill into the botoom of the post then run cable to the top ?
If not then what do i need to run cable up along side of the post or even along side the top or bottom rail
Any help will be greatly appreciated
oddball is offline   Reply With Quote
Old 09-10-2015, 10:16 AM   #2
Rewards Points: 2,350
Personally I wouldn't be against running a GFCI protected circuit in UF cable inside of a fence rail. Maybe sleeve some Seal Tite over it as well.
Old 09-10-2015, 11:58 AM   #3
Rewards Points: 14
Thank you
Can i run the UF cable int the air from under the ground to inside the fence post or does it need to be protected ?
Old 09-10-2015, 12:15 PM   #4
Rewards Points: 5,348
I would use low voltage lighting in a metal fence. No one dies if you do it incorrectly.
Ron
B. Franklin 1759
Old 09-11-2015, 07:15 AM   #5
Rewards Points: 1,626
uf cable must be protected when exposed, you could sleeve it into some pvc tubing or metallic seal tite for the lenght that is exposed before going into the post
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
oddball (09-11-2015)
Removing old Chain Link Fence Mstrlucky74 General DIY Discussions 11 09-20-2014 12:20 PM
Chain Link Fence Questions Joeboo25 Landscaping & Lawn Care 2 02-05-2013 10:50 PM
Chain link fence runoff barrier sippinjoes Landscaping & Lawn Care 4 08-16-2011 07:06 PM
Cement filled chain link fence posts johnrdz Landscaping & Lawn Care 3 02-06-2011 07:32 PM
