Rules On Running Boards? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 06:42 AM   #1
Just call me Andrew
Rewards Points: 1,032
Rules on running boards?
I am running two 14/2 and one 12/2 cable. About 8 feet of it will be on the underside of joists. i have an old 8' piece of molding - can I use that as a running board? How do i attach the wires to it? Can I zip tie them to the bottom or side of it?
Andrew
secutanudu is offline   Reply With Quote
Old 04-23-2010, 07:33 AM   #2
the Musigician
DangerMouse's Avatar
Zip ties are fine, according to my inspector, or you can wrap with black tape and staple the underside to keep it from unwrapping with time and dryness.
Staple where you can, wrap the rest.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
secutanudu (04-23-2010)
Old 04-23-2010, 09:09 AM   #3
Just call me Andrew
Can I just ziptie them to the underside of the board?
Andrew
Old 04-23-2010, 09:54 AM   #4
the Musigician
Don't see why not, I like to secure every 12" or so, in case I or anyone ever needs to traffic the area, the wires will not snag anything.
DM
Old 04-23-2010, 10:06 AM   #5
Rewards Points: 308
I would not have used running boards in your situation. I only use running boards when I am under the joist, not on top.
J. V. is online now   Reply With Quote
Old 04-23-2010, 10:08 AM   #6
Just call me Andrew
I will be running them under the joists (I assuming you were talking to DM).
Where in the NEC does it describe the use of running boards? I'd like to see what it has to say specifically just to fill my curiosity.
Andrew
Old 04-23-2010, 10:29 AM   #7
the Musigician
LOL My pic is showing my RAFTER joists, not floor.....
it'd be kinda hard to put up my 5/8" Fire-X drywall had I put them on the underside!
DM
Old 04-24-2010, 11:44 AM   #8
Rewards Points: 308
Section 334.15(C)(A) NEC 2008
"Mike Holts Illustrated Guide to Changes to The NEC 2008" has some great pictures. I was lucky to have Chris Kennedy give me a copy. Real good guy. Check figure 334-1.
The Following User Says Thank You to J. V. For This Useful Post:
secutanudu (04-24-2010)
Gate post ledger boards Klawman Building & Construction 5 04-14-2010 01:22 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
running boards for electrical in unfinished basement paulyg Carpentry 2 01-26-2010 09:21 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
