Rough-in Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 09:58 PM   #1
Rewards Points: 150
Rough-in questions
I'm about to start an electrical project in my detached garage. Permit has been pulled & posted. Have a couple questions about rough-in inspections. Hopefully these are generic enough to get an answer.
I have an existing 200a panel with a couple breakers from when the garage was built. I'll be filling the panel up.
  1. Should breakers be installed for rough-in?
  2. If yes to 1, should homeruns be wired into the breakers?
  3. Should the recessed lighting cans be fully wired in, or should there just be a section of wire flopping near the can?
Thanks much -- may have more questions a little later.
sheslostcontrol is offline   Reply With Quote
Old 12-30-2010, 10:01 PM   #2
Licensed electrician
Rewards Points: 3,662
Breakers should not need to be wired in but you can if you choose. The home runs can be cut into the panel.
The recessed will need to be wired.
Old 12-31-2010, 07:10 AM   #3
Scared Electrician
Saturday Cowboy's Avatar
talk to your inspector to find out was he wants to see.
Saturday Cowboy is offline   Reply With Quote
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
questions about rough wiring FanZ Electrical 4 05-31-2008 10:08 AM
