Rough-in Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 11:35 PM   #16
A Dangerous Tinkerer
Originally Posted by plummen View Post
that sucks,around here its paid for in the permit.
Homeowners permit is only $25 here in Delaware... so dunno if your's would be more expensive where you are.
mindle is offline   Reply With Quote
Old 02-14-2010, 11:36 PM   #17
Originally Posted by Jim Port View Post
You can use a two pole 90 in the main panel to feed the subpanel.
What about the subpanel? Should that also be a 90, or is the 100A one alright? Just sounds odd to me that I could use a 100A 'main breaker' in the subpanel to feed from a 90A breaker in the main.
Old 02-15-2010, 04:22 AM   #18
Electrical Contractor
kbsparky's Avatar
No need to change the main breaker in the sub-panel. It is not required to have it, since the feeder cable will be "protected" by the 2-90 breaker at the main panel. You could use a 200 Amp main breaker panel if you wanted to, provided the connected load does not exceed the 90 Amp feeder capacity.
-KB
Old 02-15-2010, 07:56 AM   #19
Okay... that makes sense then, I just thought I read somewhere that you need to be able to shut off the sub at both the main and inside the sub.. i guess i just assumed they would have to be the same. thanks again kb.
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Rough Opening issues for interior Pre-hung door get2bill Carpentry 3 04-04-2009 07:27 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
