Roof Tie Off Points For Lightning Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2014, 11:08 AM   #1
Rewards Points: 528
Send a message via AIM to theatretch85
Roof tie off points for lightning ground?
I am a low voltage installer, and have encountered an install on the roof of a commercial building for a network radio that communicates with another building downtown. Per the NEC the radios and the lightning arrestors associated with them need to be properly grounded. Section 800 says the length shall not be more than 20ft and if more than 20ft install another ground rod and bond to the electrical system with not less than a #6 ground wire. This being a roof I can't install a ground rod obviously, but can a roof tie off point like in the picture below be used as a connection to building steel and would I still need to bond with a #6 to an electrical ground in the building? My only pathway is the conduit for the low voltage cables, and per the NEC you should maintain at least 6ft of separation from the communications cables. Also, where PVC pipe is installed on the roof for the purposes of physical protection and attachment of cabling, is it a requirement to glue all fittings if the cabling is outdoor rated?
theatretch85 is offline   Reply With Quote
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 05:23 PM
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Metal roof energized (showing 29 volts to ground) bluefitness Electrical 5 05-07-2010 10:33 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
