Romex Through FMC For Exposed Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2019, 12:52 PM   #1
Rewards Points: 4
Romex through FMC for exposed wiring
I'm running a feed from the breaker panel to a new outlet under my kitchen sink to power the dishwasher and garbage disposal (on a 20A GFCI/CAFCI breaker). The outlet needs to be half hot so the garbage disposal can be switched, and I'm running 12/3 Romex to and from the outlet with one powering the outlet and the other acting as a switch leg.
Because the cables running to the outlet will be exposed under the sink, I'm running them through 3/4" FMC down into the basement and into a junction box on the joist directly underneath. In terms of spacing and derating, can I run two 12/3 cables through 3/4" FMC for the short stretch between the outlet and the junction box?
Cheers
mickinj is offline   Reply With Quote
Old 11-05-2019, 02:08 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Re: Romex through FMC for exposed wiring
You doing it the hard way and don't need 12/3 cable. Run 2 wire to box under sink and a 2 wire to the switch.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 11-05-2019, 02:41 PM   #3
Rewards Points: 4
Realizing I had a total brain fart writing that post. I actually am using 2 wire (12/2). In that case, doing it the way I'm doing it is ok?
