Romex Simpull - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 12:35 PM   #1
Question
Romex simpull
Is ROMEX SIMPULL within NYC CODE in a two family house Directly under vinyl siding for exterior lighting?
Looks like a opening in the insulation was made for the ROMEX SIMPULL to lie in and then just covered with vinyl siding.
Is this considered a wet area or damp area?
I think it might be 12 gague or something like it.
I was told about a code # 334.12(B) (4)
I am somewhat confused about the interpertation of this code.
I am not sure this should be used outside going across under siding like a conduitit.
Not sure if it good even in conduitit?
Also just in case of decorating or hanging something- could it be a fire hazzard?
Anyone that knows this kind of info please answer.
I called the NYC coding dept. and was told not within code.
I called NYC inspectors and was told not within code.
My contractor and a neighbor said it is within code.
My contractor said the NYC code dept is lieing to me.
Please help.
This contractor said he would put my conduitit under the siding.
Then the siding guy came and said can't cover it - would stick out.
Siding guy talked to the contractor and they changed it.
Left a piece of scrap of it and I went to the computer and my questions began.
Please help.
taras1 is offline   Reply With Quote
Old 10-31-2010, 12:44 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,970
Did your contractor have in inspection and pull a permit. He should have. When the inspector comes he will fail it most likely. Does your contract state all work is to be inspected and to code?
Old 10-31-2010, 01:12 PM   #3
Rewards Points: 2,800
Note that the cable may not be laid in a notch in a stud and run less than 1-1/4 inches from the edge of the stud where the siding is nailed or stapled on, unless a metal plate intended to protect wiring has been put over the notch with the wire in it.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 10-31-2010, 02:46 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
=taras1;526137]
well, those are the guys that count and if they say no, then it's no.
. that's a new one on me. Can't say I have ever heard anybody tell me the inspector is the one lying in such a situation.
Please help.
have your contractor call the inspector out before it is covered. If the inspector says it's good, it's good. If he says no, unless your contractor can convince the inspector it actually is a legal install, then it's no and it gets changed.
No Romex underground ... sirsparksalot Electrical 46 10-08-2014 04:41 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
