RiteTemp Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 09:59 PM   #1
RiteTemp Thermostat
My 8000 series ritetmep thermostat will not allow me to change the temp, and the website does not offer much help, any suggestions?
jemumbach is offline   Reply With Quote
Old 09-04-2010, 11:15 PM   #2
Seeing how there are more than 19 models in the 8000 series, can you be more specific?
Willis
williswires is offline   Reply With Quote
Old 09-05-2010, 04:27 AM   #3
An old Tradesmen
Rewards Points: 2,930
Sounds like time for a new thermostat.
Old 09-06-2010, 04:35 PM   #4
Master Electrician
SD515's Avatar
Rewards Points: 506
If the tempature 'hold' feature is activated, you won't be able to change the 'set at' temp. On mine, (model 8030...touch screen) I touch the (large) current room temp, takes me to the temp adjust screen and at the bottom it says either "hold", meaning hold feature is off and waiting for you to turn it on, or says "hold on" meaning it is on and waiting for you to turn it off.
Kyle
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Ritetemp 6036 replacement thermostat deanrfire HVAC 0 01-15-2010 01:12 AM
Ritetemp Thermostat shohola979 HVAC 4 07-10-2009 08:13 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
