Rigid Conduit To Meter Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 01:14 AM   #1
Rigid Conduit to Meter Box
Here is a problem. I am trying to run 2 1/2" rigid conduit in a wet area to a 2 1/2" threaded hub.
What would be the best way to connect up the box with rigid?
dug320 is offline   Reply With Quote
Old 05-08-2010, 04:29 AM   #2
dSilanskas's Avatar
A listed box connector
dSilanskas is offline   Reply With Quote
Old 05-08-2010, 07:09 AM   #3
Inspector/Instructor
codeone's Avatar
Thread The pipe and screw it in.
codeone is offline   Reply With Quote
Old 05-08-2010, 07:10 AM   #4
codeone's Avatar
Seriously are you talking about installing a riser? More info is need to understand what your trying to accomplish.
Old 05-08-2010, 07:15 AM   #5
Master Electrician
Rewards Points: 5,082
Thread the hub onto the pipe then connect the hub to the can. In most cases you really shouldn't need a threaded hub if you are entering the box from below.
brric is online now   Reply With Quote
Old 05-08-2010, 12:40 PM   #6
I will thread the pipe.
Old 05-09-2010, 10:02 AM   #7
Rewards Points: 308
Top of meter or bottom? No need for a hub on bottom or bottom side.
Old 05-09-2010, 01:15 PM   #8
Top of the box.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
SE Conduit & Meter placement acerunner Electrical 11 03-18-2010 08:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 08:31 PM
