Rewiring With A "Star" Configuration - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 07:22 PM   #16
No offense to anyone, but this has gone from a moderately messy octopus design, to a complete cluster$%^$ in the making
Agreed.
Run romex all the way to the panel. Every splice you make is a potential for failure.
Avoid splice boxes in the attic unless it's a really accessible attic.
As far as drywall patch, it almost as easy to run 2 wire as it is to run one. Take the easiest paths available. Also, drywall patch is easy in closets because no one really sees them. Actually, drywall patch is pretty easy most anywhere. I bet a guy would come in and patch the whole house for under $200 if you save all the pieces.
Be aware that if you run the cable thru the "new" wall, it will be a surprise/nightmare if someone wants to eliminate that in the future. I like to keep things "stock".
220/221 is offline   Reply With Quote
Help! Rewiring 3 prong to 4 prong cord rickysnaffi Electrical 7 07-07-2009 10:28 AM
Rewiring a whole house greengiant Electrical 25 02-20-2008 07:30 PM
Weird HVAC configuration need your thoughts Rikky HVAC 2 09-10-2007 03:11 PM
NEC code on rewiring? diverdaveman Electrical 15 07-11-2007 05:42 PM
Circuit configuration??? Clutchcargo Electrical 11 05-30-2007 08:01 AM
