Rewired Fish Tank Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 11:43 PM   #1
Rewired fish tank fixture
I converted my pin base fluorescent fish tank fixture to the screw-in type, but so far it hasn't gone as planned. I have done this before but the only difference is that this fixture doesn't have a switch like the other one. I found a way to rewire it to make it work but so far only one of the bulbs turns on while the other one flickers at first but then stays only dimly lit. I have changed bulbs and wires but no matter what I try only one bulb stays brightly lit while the other one is barely on. What seems to be the problem? Both bulbs are 20 watts each.
I have attached a photo of what it looks like and a diagram.
Thanks in advance.
Rewired fish tank fixture-100_6569.jpg   Rewired fish tank fixture-diagram.jpg
Darksome is offline   Reply With Quote
Old 01-13-2010, 12:48 AM   #2
" Euro " electrician
frenchelectrican's Avatar
What you did is hook up in series that why the lights work very funky .,
now what you need to do this in correct way what we call parllel connection so what it mean for your zip cord you will have to look little more closer the smooth side is hot while the ribbed or marked is netural so what you have to do .,,
get two yellow wirenuts {Marttee } .,
make two pig tails each so total of 4 but follow the instruction carefull if done right both bulbs will lit up nice.
take the ribbed zipcord and two pigtail { white one or ribbed } and that pigtails will go to silver screw.
then take the smooth one and two pigtail that will go to brass colour screw and you are good to go.
However you will have to get proper support for bulb socket you can not just leave them hanging loose at all.
Merci,Marc
Old 01-13-2010, 04:44 AM   #3
the Musigician
DangerMouse's Avatar
i'm curious as well.... how are you mounting the sockets?
here's what marc described.
DM
Old 01-13-2010, 11:15 AM   #4
Rewards Points: 612
You have the bulbs connected so they only get 1/2 voltage each. CFL bulbs will not work on 1/2 voltage. Incandescent bulbs will work at 1/2 brightness.
Hook it up as shown above and it will work just fine.
Old 01-13-2010, 05:06 PM   #5
I only have one wire, the one that came in with the lamp fixture...it's copper (hot)...on the new diagram there are two wires but where do I connect the ribbed/ silver (neutral) wire? I'm not much of an electrician so please keep it simple, the wording that is. I'll have no problem putting it together after that. I got lost on pigtails and onward.
I have a holding bracket for the sockets that I will just screw into place.
Old 01-13-2010, 05:14 PM   #6
the Musigician
one wire?
the plug should have 2 wires connected to it. one hot and one neutral.
if not, you need a new plug and wire.
wire according to above diagram and you'll be fine.
(hot goes to small end of plug, neutral goes on larger side)
DM
Old 01-13-2010, 05:40 PM   #7
Originally Posted by DangerMouse View Post
one wire?
DM
Sorry for the confusion. The plug has two wires, which I'm assuming are both hot and neutral, but they are both copper.
Old 01-13-2010, 05:45 PM   #8
the Musigician
trace small plug spade to hot, large to neutral.
DM
Old 01-13-2010, 05:53 PM   #9
Understood.
Now on the new diagram, how do I attach the copper (neutral) wire to the ribbed/ lead (neutral) wire? The ribbed/ lead wire isn't attached to the plug. Can these two touch, put them in a wire nut?
Old 01-13-2010, 06:15 PM   #10
300zx's Avatar
Post
Merci,Marc
Follow frenchelectrican directions. A pigtail connection is for more than one wire to be connected to a device.
300zx is offline   Reply With Quote
Old 01-13-2010, 06:19 PM   #11
the Musigician
make another black jumper wire and wire it this way.
no wirenuts needed.
DM
Old 01-13-2010, 06:23 PM   #12
300zx's Avatar
Like this except you will have two wires going to device(lights) insted of one . One for each light then you will have to do the same for the hots
Old 01-13-2010, 07:29 PM   #13
This is what I have in mind. Would it work?
Old 01-13-2010, 07:34 PM   #14
300zx's Avatar
Post
Yes That will work.
Old 01-13-2010, 09:32 PM   #15
I rewired it just like in my second diagram and both bulbs turned on.
Thank you everyone!
Fish tank plumbing problems.. Raibaru Plumbing 2 12-15-2009 02:13 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
GFCI for a fish tank? fw2007 Electrical 6 10-05-2007 12:06 PM
