Reverse Polarity - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 07:18 PM   #1
Reverse Polarity
Does reverse polarity matter on 2 wire outlets that have no ground. If so how do you check this?
scrubby18436572 is offline   Reply With Quote
Old 04-23-2010, 07:55 PM   #2
Rewards Points: 2,800
Most equipment will still work but there is a slight loss of safety. The most common example is an ordinary light fixture. The socket shell should be connected to neutral since it is more easily touched compared with the center contact when the bulb is changed. Anything that does not work (such as a touch pad activated light fixture) needed a ground, not just correct polarity.
For plugs both of whose prongs are equally sized there is no difference.
The larger slot is for the neutral.
Testing requires a known ground. For 2 prong receptacles you could try using the screw that holds the cover plate on as ground but this is not guaranteed. You can run a long wire from a known ground, which might be a (heating) radiator, for test purposes or for grounding electronic equipment. For the latter such an informal ground wire may be connected to the equipment chassis or to the ground lug of a 3 to 2 prong plug adapter but may not be strung into the outlet box and screwed to the receptacle yoke (mounting strip) unless the other end runs down to the panel or ground electrode.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 04-23-2010, 08:28 PM   #3
Reverse Polarity
Thanks Alan. That makes sense.
Old 04-24-2010, 07:30 AM   #4
electrician
Or you could use a light stick (noncontact voltage tester). It will only light up in the hot slot.
Silk is offline   Reply With Quote
Old 04-24-2010, 08:53 AM   #5
Reverse Polarity
Thanks Silk. Ill have to try that.
"Hot" polarity compared to coax/other circuits reader4 Electrical 5 03-02-2010 02:08 PM
HOT / NEUTRAL REVERSE.... need help to fix DIYneedsHelp Electrical 10 10-05-2009 06:36 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 12:14 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
