Retrofitting Recessed Light With LEDs Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2019, 01:21 PM   #1
Rewards Points: 22
Retrofitting Recessed Light with LEDs Question
We are updating all the recessed lights in the house with LEDs. We removed most of the parts for one of the lights so far as shown here: https://imgur.com/zaYA1pE
Next, there is still something left behind, it looks like housing for the previous bulbs? As shown here: https://imgur.com/oamSbVw
My question is does the housing in the image above need to be removed as well before we retrofit the LEDs?
shoryuken778 is offline   Reply With Quote
Old 03-31-2019, 01:46 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
Re: Retrofitting Recessed Light with LEDs Question
2 ways to go.
Install a A19 LED lamp and use existing trim.
Install a LED retrofit trim that screws into existing socket.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 03-31-2019, 02:03 PM   #3
Rewards Points: 22
Originally Posted by rjniles View Post
2 ways to go.
Is this an example of what you are talking about? https://www.lightup.com/led-5to-6-in...YaAl9rEALw_wcB
Old 03-31-2019, 02:37 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
Yes that is a retrofit trim. BTW, that is a great price if the quality is good.
Old 03-31-2019, 06:37 PM   #5
Rewards Points: 472
That's a Lightolier recessed housing. Lightolier does not make a retrofit fit for that model. You removed some of the trim, the glass and outer ring. The rest of the trim is what you are seeing in the ceiling. You can remove the rest of the trim if you want to but I would not do that.
Just a note, if you remove the rest of the trim, you'll see the floor joists and junction box for the light fixture. To remove it, spin the trim left or right and it will be released from the tension springs. Then compress the two tabs on the trim near the socket. To re-install, find the three or four tension springs on the housing and turn them toward the center of the opening. Re-attached the socket and push the trim straight up without spinning it.
I would try Home Depot. Look at their 6" Halo LED retrofit with adjustable color. See if you can get one to fit. I've had good luck with these trims and you'll like the ability to adjust color from 2700K to 5,000K. These are also compatible with a wide variety of dimmers. HERE"S A LINK
2700K looks good on most furniture, 4,000K looks good on white cabinets.
Let it Snow is offline   Reply With Quote
Old 03-31-2019, 07:44 PM   #6
Rewards Points: 58
I likewise recommend keeping the existing housing and trims, just use the same style bulb in LED. Why make it complicated at 6 times the cost?
Wiredindallas is offline   Reply With Quote
Old 03-31-2019, 08:06 PM   #7
Rewards Points: 22
To clarify, are you saying keep all of the existing housing that I showed in the original post, and just get a LED A19 bulb and screw that in? Don't get a halo retro refit kit?
Old 04-01-2019, 01:35 PM   #8
Rewards Points: 472
That's an option. I was trying to get a more modern look by using a step baffle.
Led come dimmable and non-dimmable.
Learn the color difference in degrees Kelvin. If you're trying to match the old incandescent, try a 2700K and see if you like that color.
Old 04-01-2019, 03:52 PM   #9
Rewards Points: 58
I understand wanting a new look, so I would possibly buy new standard bulb trims and get LED bulbs. I like to have flexibility on the bulbs both coverage and color Kelvin.
Old 04-01-2019, 04:42 PM   #10
Rewards Points: 7,496
Besides saving money, when one lamp dies, maybe 5 years from now, you simply replace it with another A19 bulb. Rather than trying to find the closest looking model for the retrofit kit that they don't make anymore.
SPS-1 is online now   Reply With Quote
Old 04-01-2019, 06:00 PM   #11
Rewards Points: 472
I know the recessed light is Lightolier, it's on the label of the trim in your photo.
There's a good chance that the housing in the ceiling is a Lightolier 1102-P1. They've made them for decades and are still available. To find out, remove the trim as I described in an earlier post. Measure the ceiling opening, it should be 6 13/16". Also measure the "Cup" with the lamp socket. Take photos and post them. Try to photo the housing from up in ceiling.
If it is 1102-P1, there are a wide variety of trims available. Most will accept a LED lamp.
Insulating above recessed light in soffit HeloOne Insulation 20 12-10-2018 08:40 PM
wiring a traffic light - motion sensor question Porsche986S Electrical 2 10-16-2018 03:55 PM
General question about cost/energy use of additional lightbulbs to a ceiling light popo619 Electrical 15 05-12-2013 09:46 AM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
My light fixture / socket question. Getson Electrical 13 02-25-2009 03:41 PM
