Replacing Telco Cables - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 04:47 PM   #16
Originally Posted by tns1 View Post
Does it make any difference signal-wise if this one splitter is right at the coax entry in the garage, or placed 100ft away? If it is centrally placed in the attic where I already have the other connections, I save 300ft of cable.
Yes. Place it where you would have the least amount of cable to run. If you can split it in the attic and then run your drops from there, do that. Do you have a cable modem? How many cables outlets do you need to feed?
jerryh3 is offline   Reply With Quote
Old 11-18-2009, 04:50 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Not that splitters go bad all that often, I would caution you to put it somewhere you won't mind accessing if there are problems you need to troubleshoot.
Old 11-18-2009, 11:41 PM   #18
Rewards Points: 322
Right now its just two TVs and one cable modem, but I have installed coax/Cat5 outlets in each room and left pull strings, so potentially there could be 5 or 6 coax outlets total. I doubt I'd ever have more than the two TVs, but I'll probably pull the coax for each room up to the attic and leave them unconnected. As I understand it, a 3-way split is no problem, but going 5 or more may require an amp.
tns1 is offline   Reply With Quote
Old 11-22-2009, 11:26 AM   #19
Rewards Points: 322
The installers had no problem with the voice port box being moved inside. All of the new installations use a cable/voice modem which always mounts inside. TV picture is so much better with all new cabling.
Earlier I had converted one corner of a clothes closet into a wiring closet. I added a power outlet and a square of plywood on one wall, and on this I have mounted a small patch panel and router. I added the 3-way splitter on this board rather than up in the attic. Those trips to the attic are hard on the knees (and sometimes the head).
One installer said when connecting splitters, the cable modem should be fed with the strongest signal, which is how I connected it. Another said the big TV should get the strong signal. Both work better than before, but if I am real picky I can see some very small 'sparkles' in an HDTV channel, which looks like interference. These are not noticeable on a non-HD channel since the picture is so much grainier.
Old 11-22-2009, 12:59 PM   #20
nap
You talking to me?
nap's Avatar
=tns1;356475]The installers had no problem with the voice port box being moved inside. All of the new installations use a cable/voice modem which always mounts inside.
sounds like FiOS or your telco is much more involved there than our is here.
just wanted to be sure.
. that's why I suggested serviceability factor.
nothing is perfect and as long as the signal is well withing accepted levels, it shouldn't make any difference what feeds what.
good to hear all is up an runnning
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 08:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 06:53 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
