Replacing Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 11:06 AM   #1
Unhappy
replacing receptacles
I am in the process of replacing old receptacles, when I opened up the box I found two sets of black and white wires, my new receptacles only has one outlet, I connected one set of the black and white wires and put wire nuts on both the other sets, now the receptacle works but celling lights in the room do not, first question is are the lights on the same circuit, second question is if so how do I reconnect the circuit? just connect the remaining black and white wires together?
thanks...
Alex007 is offline   Reply With Quote
Old 01-08-2010, 11:10 AM   #2
You disconnected the power that goes thru the box to the other devices
What do you mean the new receptacle only has one outlet ?
Is this a 15a or 20a circuit ?
Ourlets normallu have 2 screws on each side
Black to brass, white to silver color screws
Then grounds are all connected together & one runs to the grounding screw
Do you have a pic of the setup ?
Old 01-08-2010, 11:21 AM   #3
receptacle with one outlet and nightlight
I mean there is only one place to plug in a plug, the other is taken up by a night light (its called a Nightlight/outlet - legrand)
Yes I understand I have disconnected the lights, so how can I reconnect them?
The new receptacle is 15amps
thanks
Old 01-08-2010, 11:27 AM   #4
just to clarify this receptacle has only one screw on each side, meaning it only has one outlet, I have attached a picture,
thanks
Old 01-08-2010, 11:29 AM   #5
So something like this ?
And you only have one screw on each side ?
In that case you will need to pigtail all the wires together & use the pigtail to connect to the outlet
Pigtail:
Old 01-08-2010, 11:36 AM   #6
yes thats it exactly, so I can pigtail 4 wires of each color together, that would require a very large wire nut and the box is extremely cramped, is that ok?
Old 01-08-2010, 11:42 AM   #7
Do you have three sets of wires now or just two? From the way i understood your post you have one set incoming power and one set outgoing, is this correct?
Paelectrican is offline   Reply With Quote
Old 01-08-2010, 11:42 AM   #8
You have 4 wires of each color = 4 cables.....= 9 total for box fill = 18 cu inches needed + 4 for device
So you need a 22 cu inch box if my math is right for 15a circuit
That will meet code if your box is big enough - ~3.5" deep
If one set went to a switch that may have been a hot switch loop
Did you note where all the wires were connected when you took this apart ?
Old 01-08-2010, 11:47 AM   #9
4 wires?
You will only have 3 wires in each wire nut.
The 2 black ones coming into the box and a little piece of black wire that you add and that goes to the receptacle in one wire nut. And 2 white ones coming into the box and a little piece of white wire you add that goes to the receptacle in a second wire nut. The ground wires do not need a wire nut just need to be attached to the box and the receptacle if the box is metal or just firmly twisted together. Although if you're not comfortable with wiring, then a wire nut might be a good idea on the ground too because it will hold better.
Yellow coloured wire nuts can fit 3 14 gauge wires or the brown twister type
trosenda is offline   Reply With Quote
Old 01-08-2010, 11:59 AM   #10
to try and clarify , I had, 4 wires of each color, ie 4 white and 4 black. previous set up was a receptacle with two connectors on each side, therefore each connector had 2 of each color pigtailed and connected, now if I pigtail everything I will have 5 wires in each wire nut, 4 incoming pigtailed to the single one in each color, the wires are pretty thick gauge, is it really going to be possible to pigtail all that together?
Old 01-08-2010, 12:04 PM   #11
Can you provide pictures? So right now you have 4 white and four black already in the box? How big is your box? If only a duplex receptacle was in there i believe you are gonna have to change the box, you may already exceed the amount of wires permitted in your box.
Old 01-08-2010, 12:19 PM   #12
yea I agree I think I need a larger/deeper box, I will try and get pictures later.
thanks
Old 01-08-2010, 12:22 PM   #13
You can only have ONE wire going around the screw...not (2)
You would have been far better off leaving a normal receptacle & plugging a night line into the plug
Tags
receptacle , replacing , wiring
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
replacing wire to ceiling lights jheavner Electrical 5 11-04-2008 07:42 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
