Replacing Normal Breakers With Doubles - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 12:33 PM   #1
Rewards Points: 214
Replacing normal breakers with doubles
Is there a way to replace normal breakers with doubles without shutting off the main breaker? I am getting ready to install a sub panel and need to free up two spots to put in my 100 amp breaker.
Abs777 is offline   Reply With Quote
Old 02-17-2010, 01:28 PM   #2
Just call me Andrew
Rewards Points: 1,032
You can change out breakers with the main ON...but why would you want to take that chance? Is there a good reason why you can't shut the main off?
Andrew
secutanudu is offline   Reply With Quote
Old 02-17-2010, 01:44 PM   #3
Rewards Points: 214
I just didn't want to cut power to the whole house. I would much rather be safe though. If I turn off the main breaker in the panel will there be any danger in the panel or will everything be dead?
Old 02-17-2010, 01:47 PM   #4
Just call me Andrew
The incoming lines to the main breaker (two screws) are always live unless they cut power before it enters your house.
Andrew
Old 02-17-2010, 01:52 PM   #5
Rewards Points: 214
Right. I was wondering about the bars (main and neutral).
Old 02-17-2010, 02:11 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,512
Ayuh,... That's beyond the Main,.. It's dead after switching the Main off...
Only the Big wires going to the Main,+ the associated lugs will remain Hot...
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 10:19 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 06:08 PM
